Rust removal - NCRS Discussion Boards
Rust removal
  • Gary B.
    • February 1, 1997
    • 7082
    #31
    • Frank D.
      • December 27, 2007
      • 2703
      #32
      Re: Rust removal
      I agree...anybody that's dealt with caustic stuff like Ospho will embrace EvapoRust. The only issue is that the original solution is meant to "dip" parts in to soak, there is an EvapoRust gel for vertical and hard-to-reach surfaces but it cones in a smaller volume and isn't cheap.
      • Ed S.
        • August 6, 2014
        • 1390
        #33
        Re: Rust removal
        For larger parts that are too large to be submerged overnight I wrapped them in paper towels or old terry-cloth rags that were dripping with Evapo-Rust. Then, I wrapped the paper towels in a clear plastic food wrap (Saran Wrap) and let it sit overnight. The clear plastic wrap prevents the solution from evaporating. This would probably work on vertical surfaces as well.
        Ed
        • Floyd B.
          • November 1, 2002
          • 1053
          #34
          Re: Rust removal
          FWIW, I use cosmoline as a preservative / rust inhibitor. I don't know if the General ever used it but it has been around for more than a hundred years and used by the military to coat and preserve just about anything metal.
          Cosmoline Direct offers All Classic & Modernized versions of Cosmoline Rust Preventatives, Aerosols, Greases, Sprays & More. Next-Day Delivery Now Available!
          "Drive it like you stole it"
            • 11698
            #35
            Re: Rust removal
            Originally posted by Keith Wiethe (64808)
            Patrick, do you prefer the 400 over the 350? If so, just curious as to why. I have been using the 350 to clean things up and leave it on for storage . If 400 is better than maybe I should switch. Thanks
            Each has their purpose.
            I use the 350 as well on chassis parts to maintain a "less rusty" look.
            The 400 is thicker, and closer to what was on the springs originally.
            I think that Cosmolene is too thick.
            While you can spray them on, I often brush them on or use large swabs to apply.
            • Mark E.
              • April 1, 1993
              • 4614
              #36
              Re: Rust removal
              What a great tip. I use the gel for large parts or parts on the car. But I like this idea.
              Also, for plated metal, be careful how long EvapoRust is applied.
              Not long enough ==> Still rusty
              Too long ==> Plating removed
              Just right ==> Rust gone, plating intact
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Michael G.
                • November 12, 2008
                • 2158
                #37
                Re: Rust removal
                The finished springs
                Evapo Rust did a great job, with minimal work… I also had set of springs that I had blasted, with nowhere near the the clean, rust-free result obtained with the Evapo Rust.
                There are coatings available that would last essentially forever on these, with no rust, but I opted to to mimic the original look, rather than worry too much about corrosion on a car that will likely not be driven in the rain. (It’s a C2 convertible, so it rains inside the car during a storm - with the top up). My coating does protect them from exposure to water spray, and is flexible, but I’m not absolutely sure of its long-term durability on a spring. Wish me luck.
                Mike
                1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
                • Gary B.
                  • February 1, 1997
                  • 7082
                  #38
                  Re: Rust removal
                  Mark,
                  The Caswell Plating website, on their EvapoRust page, says:
                  In my experience with using EvapoRust, if a zinc-plated fastener shows an obvious rust bloom and is a candidate for soaking in EvapoRust, then the zinc plating is no longer sufficiently or uniformly intact and the item likely needs to be stripped and replated in order to fully restore it.
                  Gary
                  • Brian M.
                    • November 1, 1994
                    • 137
                    #39
                    Re: Rust removal
                    Very nice.
                    Brian McIntyre
                    • Floyd B.
                      • November 1, 2002
                      • 1053
                      #40
                      Re: Rust removal
                      Evapo-Rust (and other similar products) will remove ANY and ALL sacrificial coating on the metal part. It's great for removing rust from parts that should have a natural finish or stripping any existing/remaining coating in preparation for re-coating but you don't want to use it if want to keep any existing plating that remains.
