Rust removal - NCRS Discussion Boards
Rust removal
  • Gary B.
    • February 1, 1997
    • 7083
    Re: Rust removal
    Nice job!
    Gary
    • Gary C.
      Administrator
      • October 1, 1982
      • 17971
      Re: Rust removal
      Rust removal tool https://www.youtube.com/watch?v=sW7yxEBNDG8
      NCRS Texas Chapter
      https://www.ncrstexas.org/
        • 11698
        #18
        Re: Rust removal
        I use this:
        CRC SP-400 Corrosion Inhibitor is a long-term indoor and outdoor protection on all equipment subject to heat, humidity, chemicals, and more.
        • David B.
          • March 1, 1980
          • 691
          #19
          Re: Rust removal
          If you want to use the original factory rust proof compound. The factory spec. reads as follows:
          Spray or dip with Lucas rustproof #635 compound for rust prevention (mix 7 parts of water with 1 part rustproof compound)
            • 11698
            #20
            Re: Rust removal
            I can't find that Lucas #635 exists any longer.
            • Gary B.
              • February 1, 1997
              • 7083
              #21
                • 11698
                #22
                Re: Rust removal
                Gary,
                Thatโ€™s why I recommended the CRC400. Darker and thicker than the 350, I think itโ€™s very close to the original substance.
                Patrick
                • Mark E.
                  • April 1, 1993
                  • 4614
                  #23
                  Re: Rust removal
                  Gary,
                  Patrick
                  Which parts had this type of coating? Only the coil springs?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Keith W.
                    • May 25, 2018
                    • 204
                    #24
                    Re: Rust removal
                    Patrick, do you prefer the 400 over the 350? If so, just curious as to why. I have been using the 350 to clean things up and leave it on for storage . If 400 is better than maybe I should switch. Thanks
                    • Michael G.
                      • November 12, 2008
                      • 2158
                      #25
                      Mike
                      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
                      • Brian M.
                        • November 1, 1994
                        • 138
                        #26
                        Re: Rust removal
                        I contacted Lucas and that is no longer one of their products.
                        Brian McIntyre
                        • Keith W.
                          • May 25, 2018
                          • 204
                          #27
                          Re: Rust removal
                          Anyone heard of anything that produces similar results but with a spray-on?
                          • Gary B.
                            • February 1, 1997
                            • 7083
                            #28
                            Re: Rust removal
                            Keith,
                            Both CRC 350 and CRC 400 are available in spray cans.
                            Gary
                            • Thomas N.
                              • July 31, 2002
                              • 408
                              #29
                              Re: Rust removal
                              Your springs look great! Awesome job!
                              Gotta love Evaporust! Pricey but works!
                              NCRS New England Chapter Chairman 2022, 2024
                              N E Regional Chairman 2024
                              1967 Corvette Convertible Under Restoration
                              1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
                              • Keith W.
                                • May 25, 2018
                                • 204
                                #30
                                Re: Rust removal
                                Originally posted by Gary Beaupre (28818)
                                Keith,
                                Gary
                                Thanks Gary. Yep, I have some spray 350 but it is not as effective as the evaporust. Curious if there is another option other than 350.
