Rust removal - NCRS Discussion Boards
Rust removal
  • Michael G.
    • November 12, 2008
    • 2158
    Rust removal
    I have an pair of NOS '65 springs with light surface rust, no pitting. Looking for a non-acidic way to remove the rust and leave the surface natural. Any help would be greatly appreciated.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • 6960
    Re: Rust removal
    Mike, Spray some WD40 and let it set a few hrs.
    • Ed S.
      • August 6, 2014
      • 1390
      Re: Rust removal
      I have removed rust - more than surface rust - from various ferrous metal items with Evapo-Rust. I gotta tell you, that stuff really does a job - the parts came out like they were just cast, a nice medium grey color. Evapo Rust, is not all that cheap - you will probably need a few gallons and it is not toxic - it will not do damage to bare skin -- if you wash it off. Great stuff. If the WD40 doesn't do a satisfactory job for you - try it.
      Ed
      • Michael G.
        • November 12, 2008
        • 2158
        Re: Rust removal
        Thanks guys, so far, so good with WD40 (one down, one to go)...
        Mike
        • Gary J.
          • April 1, 1980
          • 1246
          Re: Rust removal
          Like the yellow tag
          • Gary B.
            • February 1, 1997
            • 7082
            Re: Rust removal
            Gary,
            Yelllow tags came on service replacement springs. The standard spring used on the production line had a green tag. For judging, the yellow tags need to be removed and repro green tags installed.
            Gary
            • Michael G.
              • November 12, 2008
              • 2158
              Re: Rust removal
              Thanks, the red car will likely never be judged again (already Regional Top Flight), but it can't hurt to change the tag to green. Just not looking forward to doing the spring replacement myself, but with a saggy left spring, time to do it...
              Mike
              • Gary J.
                • April 1, 1980
                • 1246
                Re: Rust removal
                If these springs are for a ‘63 or ‘64 with A/C car the tag code is supposed to be 3833319 in black on yellow tag according to the judging manual.
                • Michael G.
                  • November 12, 2008
                  • 2158
                  Re: Rust removal
                  They are for a ‘65 with AC (3851100)
                  Mike
                  • Gary J.
                    • April 1, 1980
                    • 1246
                    Re: Rust removal
                    Not sure what the ‘65 manual would say. Tony Stein may know.
                    • Michael G.
                      • November 12, 2008
                      • 2158
                      Re: Rust removal
                      The green tags with “3851100” and the proper build code (ED) are available today on the repop market, (I have some on my black car) The real tags have a different cut-off serration than the repros, so I’m going to get a set of those and tear them off with a finer-toothed tape serration.
                      Mike
                      • Gary B.
                        • February 1, 1997
                        • 7082
                        Re: Rust removal
                        In case anyone else wants to read about how to recreate the proper zig-zag cut ends:
                        https://www.forums.ncrs.org/showthre...e+coil+springs
                        Gary
                        • Michael G.
                          • November 12, 2008
                          • 2158
                          Mike
                          • Michael G.
                            • November 12, 2008
                            • 2158
                            Mike
                            • Michael G.
                              • November 12, 2008
                              • 2158
                              Re: Rust removal
                              Just got my new tags from Paragon and changed the cut-off serrations:
                              Mike
