Mice - NCRS Discussion Boards
Mice
  • Nick C.
    • August 31, 1998
    • 542
    #31
    Re: Mice
    Sure does, as Jimi would say " 'Scuze me while I kiss this guy..."
    Not quite correct... a little research prior to misquoting as Mondegreen is in order.
    • Steven B.
      • June 30, 1982
      • 3986
      #32
      Re: Mice
      Originally posted by Clem Zahrobsky (45134)
      mike the pink RV anti freeze is not poison as it is to be put into the water lines in RVs, but it still drowns them. you could use corn liquor and the mice would die happy.
      -------and, the pink tastes much better than the old green stuff. More like cotton candy than vegetables. I am unsure how it would taste in the pot pies, though. After this I may become a vegan.
      I also use the outside bait box and it works well. Inside I use moth balls. I will try the dryer sheets. I have purchased 2 of the sound generating boxes over the past three decades and they have never worked for me. I even found droppings on top of one of them. While living near Atlanta years ago we had a walkout basement I used to store three cars. I found a couple of small entry openings and used wire screen and spray foam insulation that worked very well in sealing. My neighbors two yellow cats, the Butter Brothers, helped me out last week with a mouse trying to break and enter.
      • Steven B.
        • June 30, 1982
        • 3986
        #33
        Re: Mice
        Hell, Clem, don't waste the precious corn squeezin's, if you use liquor, use that store bought stuff.
        'Back when I was in the AF, ours, there was a guy who drank Aqua Velva apparently with the results he was looking for. He smelled good from 50 feet.
        • Michael J.
          • January 27, 2009
          • 7119
          #34
          Re: Mice
          I know, but I love the line anyway....
          • Ray G.
            • May 31, 1986
            • 1189
            #35
            Re: Mice
            Hello;
            A friend owns an Auto Trim Shop (interior repairs).
            Each spring he will get many rodent repair jobs and I will do many wiring repairs due to mice and other rodents.
            We often remark to each other "rodents eat dryer sheets but don't come around moth balls".
            We use them at building door openings and around tires and any other place mice can climb into the vehicle or boat. They can't jump very far.
            The traps work, but poison presents the problem Mike McCagh referred to "not being able to find the carcass and the stench".
            my .02
            Ray
            I hope you dance
            • Philip P.
              • February 28, 2011
              • 558
              #36
              Re: Mice
              I have not had any dryer sheets eaten, as for the moth balls I am not sure that is a smell that I can stand for very long, it takes some time and a lot fo fresh air to get rid of but I guess the its better than dead mice. I have not seen any evidence of mice since using the dryer sheets, music etc, they may not like oldies.
              PHil
              • Ray G.
                • May 31, 1986
                • 1189
                #37
                Re: Mice
                Hello Phil;
                Believe moth balls are just crystalized naphtha. Just need to ventilate the area to clear the smell.
                I always wonder how the price stays so low on Moth balls when you consider the reaping that must be involved and how many moths it takes to fill a box.
                Ray
                I hope you dance
                • Philip P.
                  • February 28, 2011
                  • 558
                  #38
                  Re: Mice
                  Ray,
                  I am still smiling, that was a good start to a very cold day here in the Pacific Northwest.
                  Thanks again.
                  Phil
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    #39
                    Re: Mice
                    Phil,
                    If you don't like the smell of moth balls (and who does), you might try Irish Spring. I have a bar in each corner of my garage, no mice so far.
                    Joe
                    • Philip P.
                      • February 28, 2011
                      • 558
                      #40
                      Re: Mice
                      Joe,
                      I did forget to mention the Irish Spring I have bars placed around my building, maybe that is the reason for no mice. Seems like there is a wealth of ideas for keeping the little critters away.
                      Phil
                      • Chris H.
                        • April 1, 2000
                        • 837
                        #41
                        Re: Mice
                        I had chuckle last spring when I started up my sportbike (Kawaski ZX11) after the winter. I turned around and the whole driveway was covered with mouse nest. Turns out they had built nests in both mufflers.
                        I vote for the good old fashioned spring traps.
                        • Tom N.
                          • May 6, 2012
                          • 42
                          #42
                          Re: Mice
                          Fresh Cab Botanical Rodent Repellant is safe for all concern and keeps mice out!!!
                          • Raymond W.
                            • September 30, 2003
                            • 248
                            #43
                            Re: Mice
                            I have used dryer sheets and traps with success, haven't used the radio idea. Living in the Northeast where you get fluctuating warm/cold temperatures, I found that a Car Capsule with a low voltage fan that moves the air keeps any moisture condensing on the car and also takes care of keeping the mice at bay.
                            • Michael J.
                              • January 27, 2009
                              • 7119
                              #44
                              Re: Mice
                              "Not a creature was stirring, not even a mouse".....Feliz Navidad.
