Re: aviation fuel in 64 fuelie
Pat,
On a road trip, where practical matters dictate using pump gas, do this: EVERY time you stop, open the hood. This lets engine heat out and cools the spider. When you are ready to re-start the car, start the engine before you close the hood and immediately drive away.
When I say "every time you stop", I mean that literally. Stop for fuel? Open the hood. Stop at a rest area? Open the hood. Stop for food? Open the hood.
My bride and I did this when we drove our FI '60 from CA to a regional in Steamboat Springs CO and it worked like a charm. The engine re-fired easily and ran smoothly every time.
Two other suggestions:
1. Be sure your hot starting technique is proper: Wide open throttle and crank until the engine starts.
Corollary: If the engine doesn't re-fire quickly when you do the above, it wants fuel. Take your foot off the accelerator and crank the engine.
2. Be sure your car's cooling system is in top condition such that the thermostat can control engine temperature. I recommend a 160F thermostat for injected cars.
Jim
Pat,
Jim
