Re: Joe Randolph's stroker article in the most recent Corvette Restorer
Your results probably would have yielded more torque and power with a cam of equal duration and overlap, but with more lift...................and so a "bigger" cam, which is where I was going in my reply. Since the major part of flow restriction is across the valve seat, some more lift would increase flow considering your heads are fairly big @ 200 cc.
It looks like your Iron Eagle heads will accept up to .600 lift using a hydraulic roller with their standard springs. It would be interesting to see flow ratings with valve lifts up to .600 and I suspect that the rating @ .600 would be close to that @ .500 lift. Assuming that's true, I'd be looking for intake lift of something like .550 (mine is .610, but mine is a solid roller of longer duration). I don't remember which rockers you used, but a very strong performance improvement can be had by increasing the rocker ratio on the INTAKE side. Exhaust lift is not as important considering your restricted exhaust with those rams horns. If you don't already have them, then consider boosting your intake rocker ratio to 1.6 or 1.7:1. Not sure if Comp has a hydraulic roller intake lobe that yields more than .525" lift @ 0.050/221 duration. Maybe the "Extreme Energy" series, or a custom cam using a high lift/low-moderate duration intake lobe.
My guess is a .550-.600 lift intake would be good for another 40-50 HP. Try it on your EA sim program.
