Re: Joe Randolph's stroker article in the most recent Corvette Restorer
I think "core shift" is overhyped as is "slanted" decks. It can happen, but is not common, and, of course, there is some tolerance on positioning the cores in the mold. Just the same, having the block sonic tested in the critical areas is a good idea, and I think .030" clearance is okay. Sufficient static clearance is required to maintain clearance due to thermal and stress issues. Chevrolet recommends minimum .035" quench clearance, but many engines have been assembled and successfully operated with a lot less, and in this application you have both piston thermal expansion and "rod stretch" due to the high tensile load on the rod at TDC of the exhaust stroke.
Joe, I don't think you stated how much material you actually removed, but it doesn't look like more than about .050". Can you give an estimate?
As far as "cheater motors" are concerned, I don't have any problem with them, and I don't think most members do. As mentioned by Joe two long time, highly respected NCRS members who have held high offices did "cheater motors", and they weren't excommunicated.
I'm not a big fan of resto-rod Corvettes, but since judging is based on appearance and operational characteristics and we don't have X-ray machines to inspect inside the engine and other parts of the car, any internal mods to improve performance, function, or durability are on the table IMO, and a lot of creative talent and work have gone into the the changes that Joe and Tom have described.
