Re: 1967 Body Lift for Chassis & Frame Restoration
Hi Tom, Glad the pictorial helps.
When you replace it, just take reference measurements to get the replacement in the same position. However, the shim count may change anyways due to variations in the body placement back on the frame. In particular, on the convertible, the door gap at the top on each side will most often determine the shim count. It's trial and error as you tighten the mount bolt also.
Here's an example of another '67 convertible. It had a large gap at the door top to the rear quarter. Additional shims had to be added to get it aligned better.
This was the gap at the top of the door.
#4 deteriorated and sagged the rear quarter, bolt seized, cage & nut rusted and replaced. (this was needed both sides) I tapped the steel undercar body mount to 10-24 as I did not have the body removed to replace it using original style rivets.
By placing temporary shims I was able to close the gap.
New vs old
Final shims and new mount
Result
New vs old
Result
