Bloomington Gold juging vs. NCRS - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1326
    Re: Bloomington Gold juging vs. NCRS
    John -
    The short version is that you'll need a window price sticker, it's all over in 23 minutes, and you'll need to declare whether you think your pad stamp is original or not. More info is available at the Bloomington Gold website, and others will chime in with more detail. You'll see lots of familiar faces.
    23 minutes?????? Wow.
    Chris Enstrom
    2011 Z06, red/red
    • Jaime G.
      • April 1, 1988
      • 480
      This is hearsay. If the car has the correct appearance and you achieved it with spray cans, it will be judged accordingly.
      • Jaime G.
        • April 1, 1988
        • 480
        Contact MF Dobbins in PA. He makes the best reproduction window stickers.
        • John S.
          • May 17, 2009
          • 164
          James,Do you have contact info for MF Dobbins for window sticker order?Thanks,John
          • Paul O.
            • August 31, 1990
            • 1716
            The actual desired time is 36 minutes 4 judges 1 for each judged area and operations as a team NCRS has 10 judges 2 for each of the 5 judged areas. But you have to realize at Bloomington the judging team can have 10 cars. The max for NCRS on 1 day is 8.
            • Dick W.
              • 10483
              But that includes the time the team takes to check each others sheets and go over them with the owner. 23 minutes is about right for actual judging time.
              Dick Whittington
              • Jaime G.
                • April 1, 1988
                • 480
                John,
                here you go.
                M F Dobbins
                3045 Pennypack RD
                Hatboro, PA 19040
                dobbins3045@verizon.net
                Best of luck and say hello to Dobbs.
                • Mark D.
                  • June 30, 1988
                  • 2152
                  Just ignore the two weenies in the photo. The good looking guy is next to the hood in the blue shorts.
                  That's a nice thing to say about Alvin. I'm sure he'll appreciate it.
                  Kramden
                    • 11643
                    #24
                    Alvin?!? Simon and Theodore too?
                    • Mark D.
                      • June 30, 1988
                      • 2152
                      #25
                      More like, Alvin and Ronnie:-))
                      Kramden
                      • William H.
                        • January 1, 2006
                        • 209
                        #26
                        What is the recommended way to attach the window sticker? Thanks.
                        Bill Hyndman
                        The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
                        1962 Big Brake Fuelie
                        1965 Fuelie Convertible
                        1968 L89 Convertible
                        • Loren L.
                          • April 30, 1976
                          • 4104
                          #27
                          John, for the address of your delivering dealer in 1967, contact the Public Library in Portland - and say Thank You when they come through.
                          • Joseph T.
                            • March 1, 1986
                            • 169
                            #28
                            William,
                            Drivers side window - upper rear- mounted inside the glass and read from the outside. Glued. I think it shows it in the assembly manuals.
                            If you tape it , to the inside of the window, you will probably not receive a deduction.
                            • Richard L.
                              • May 31, 1988
                              • 156
                              #29
                              Use Double Stick Tape on the border of your Window Sticker...
                              • Ron N.
                                • August 18, 2008
                                • 243
                                #30
                                John, I also will be taking my 67 to Bloomington this year and it also is a Regional Top Flight winner (3X).
                                BG is the oldest and largest Corvette gathering I've ever been to. I was at the 2012 BC event when it was held at Pleasant Hills CC outside of Chicago. It was a great experience and I got a wealth of information talking with the judges.
                                The BG Certification is much different from NCRS Flight Judging although some of the judges do both NCRS and BG judging. There is only 1 team of judges that complete their inspection in less than 1 hour. When I planned to try for BG I searched for and fount many comments posted on the NCRS Forum. I posted my own questions and received helpful replies. When I got the BG scoring sheets I did a self evaluation using my most current NCRS scoring sheets.
                                One point I head from several people (don't know if true) is that you can expect the BG score to be 1% less than that of NCRS. That assumes your engine stamp and trim tags are true.
                                If I can help email me at ron.napoliello@comcast.net.
                                Ron
