cock pit heat/install 64 non A/C heater shut off valve? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4544
    Re: cock pit heat/install 64 non A/C heater shut off valve?
    A couple of thoughts while reading this older thread-
    - Is the problem radiant heat? This is a heat source (like exhaust pipes, engine block) that heats nearby surfaces like the floor, tunnel, firewall- making them warm or hot to the touch. Some likely causes: missing insulation or heat shields; exhaust pipes routed too close to the floor.
    - Or is the problem convective heat? This is warm air getting in the interior. Some likely causes: a heater door not working properly; holes or gaps in the firewall; bad hood seal, etc.
    Understanding the type of heat source helps troubleshoot its cause.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jack P.
      • March 19, 2009
      • 1135
      Just put a valve in the line . Or at the block . With valve off temp at box interior will be 150 degrees cooler. No plugs, just Plummer valve $5
      • Frank D.
        • December 27, 2007
        • 2703
        #18
        Here is what I did on my '61....O'Reillys has the valves; works great but I don't know all the specifics of trying it on a C2 - the expansion tank issue mentioned above could come into play.
