59-60 High Horsepower Harmonic Balancer- is p/n: 3764318 visibly stamped on Balancer? - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 59-60 High Horsepower Harmonic Balancer- is p/n: 3764318 visibly stamped on Balan
    The blueprint for 3764318 specifically calls out "No holes in the outer ring" ie, you may remove metal for balancing but do not put a hole in it.
    • Ian G.
      • September 3, 2007
      • 1114
      thanks Loren and Rich; that's a relief. Yeah DD knew what it was for. I'll call him anyway to be sure. I just figured it needed to be there, based on your original Rich...
        Originally posted by Ian Gaston (47813)
        Can someone advise if this would affect it's rotational characteristics appreciably? For example, maybe it's there to offset the balance of the Duntov cam in some way?
        Ian -
        The device has nothing to do with balance of the crankshaft or of any other component - it's a harmonic damper, designed to minimize a specific range of crankshaft torsional vibrations. The damper itself must be neutral-balanced, thus the occasional drill impression on the face of the inertia ring.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11324
          Thanks for clarifying that John.
          Ian, you said you got yours from a old Chris Craft 283. What year and model was it?
          They also had many optional engines in the old mahogany boats in the 50's and 60's.
          Reason I ask is I have a buddy in NH that has a pile of old boat engines in his barn, some are 283's.
          • Ian G.
            • September 3, 2007
            • 1114
            yes, thanks John! Rich: I bought them off eBay. Seller said it was a 64 Connie for what it's worth.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11324
              Ah.....A Continental, a cool boat. I restored one like it about 10 years ago, but it was the 'base' version, simply called "Ski Boat".. Found a few pics on the net of a Connie.....
              http://www.boattrader.com/listing/19...ntal-102253083
              Also found a cool cabin cruiser, model name...........Corvette!
              http://boats.oodle.com/detail/1955-c...-www-_-NA-_-NA
              • Ian G.
                • September 3, 2007
                • 1114
                Yeah, he said it was a 27' footer. I'm sure there's more of these "floating" around. har.
                • Ian G.
                  • September 3, 2007
                  • 1114
                  If anyone is interested, this is what the 64 Chris Craft "Connie" GM 283 balancer core looked like before machining and was 7" diameter if memory serves...
                  • Loren S.
                    • November 1, 2002
                    • 172
                    #24
                    Not mine, just saw it pop up for sale:
                    • Donald A.
                      • March 1, 1987
                      • 243
                      #25
                      I looked at the eBay balancer posted above and it appears correct 3764318, very rare high HP 1959-1960 270 & 290HP part. I looked quite awhile for mine, they are difficult to find. One I saw a couple of years ago on eBay I bid on but gave up on, it sold for $1600!! The current eBay item is at $200. Photos of mine below.
                      • Garry B.
                        • January 1, 1991
                        • 660
                        #26
                        Guys, I was looking at the pictures of the one that is currently on eBay and it appears as though there is a chunk of material missing at the edge where the two balancing holes have been drilled. What effect would this missing material have on this working correctly? Thanks.
                        Link supplied by Loren Smith two posts up.
                        Garry Barnes #18531
                        '67 Lynndale Blue Coupe- National TF, BG
                        ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
                        • Loren S.
                          • November 1, 2002
                          • 172
                          #27
                          Sold for $1,350.
                          • Garry B.
                            • January 1, 1991
                            • 660
                            #28
                            Loren, I was watching and thought about jumping in at $400.....don't need it anymore and would rather someone who needs it get it. Thanks for the heads up though?
                            Garry Barnes #18531
