67 passenger door latch - NCRS Discussion Boards
  • Todd L.
    • August 26, 2008
    • 298
    On a 67, the passenger side door latch does not latch all the time. It takes a while of closing the door repeatedly.
    there is no pattern to what works. Sometimes you close it hard and it latches other times it is closing it lightly that it works.
    Suggestions???
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 67 passenger door latch
    Sounds like the latching assy needs a good cleaning......
    • Todd L.
      • August 26, 2008
      • 298
      Is there anything I should watch out for? Does the door need to come apart to do this?
      Todd
        • 43281
        Todd
        Todd------
        The inner door panel and associated parts need to come off. As Steve mentions, the lock mechanism needs to be cleaned and relubricated. However, you need to inspect the lock mechanism for broken or worn parts. This can be a little difficult since the lock is not designed for dis-assembly. Component parts of these locks were never available from GM and the locks were serviced as an assembly only. I don't know of any parts that are now available. Of course, the locks are long-since GM discontinued.
        • Daniel Y.
          • September 30, 2002
          • 186
          Todd,
          if you need a complete assembly I can help you out. I bought one on ebay recently thinking that mine was broken. only to find out that it was an adjustment on the "free wheeling" rod
          Dan Young
          65, 67 Duntov x2
          66 bowtie x 2
          71 LT1 TF
          90 ZR1 McCelland
          03 Anniverary
          06 Z06
          • Todd L.
            • August 26, 2008
            • 298
            Thanks Dan.
            I will see what I can do with this one and go from there. Do you have a picture you can send me and a price just in case.
            Todd
            • Daniel Y.
              • 186
              send me an email @ bowtie66@ptd.net and I will send you picture this weekend
              Dan Young
              65, 67 Duntov x2
              66 bowtie x 2
              71 LT1 TF
              90 ZR1 McCelland
              03 Anniverary
              06 Z06
              • Todd L.
                • August 26, 2008
                • 298
                Does anyone have an article or reference for taking the door panels off a C2, what tools are needed?
                Going to try for this weekend to tear it apart.
                Todd
                  Todd
                  Todd -
                  See page 1B-11 in the "Corvette Body" section in the 1967 Chassis Service Manual, including Figure 29 on page 1B-12.
                  • Todd L.
                    • August 26, 2008
                    • 298
                    would the procedure listed in a 66 service manual be the same?
                      • 43281
                      Todd------
                      I think it would be substantially the same. There might have been some slight difference with respect to inner door panel removal.
                      • Edward M.
                        • January 10, 2014
                        • 40
                        Todd, I too was having similar problems on both sides. Ive only owned my 67 for a few months and it be my 1st, I carefully removed the door panels and pulled back the vapor barrier. Thru the access opening I was able to get to all the mechanisms in the door(roll the windows up first). I was able to directly and indirectly(using a mirror) to lubricate pretty much everything . It all works like a charm now. Just take your time and go at your own pace, you can do it. Any questions, just ask. Ed
                        • Todd L.
                          • August 26, 2008
                          • 298
                          to lube the latch in place, do I need a manual to remove the door panel?
                          • Edward M.
                            • January 10, 2014
                            • 40
                            I did it w/o the manual. Read a few archive articles and watched some YouTube videos. It was fun and rewarding to do.
                            A few things were a little tricky at first like removing the cranks w/o the proper tool and placing the panel back into its exact prior position. That why I said go slowly so you can do it again in reverse to put it back together .
                            • Todd L.
                              • August 26, 2008
                              • 298
                              what kind of special tools are required?
