67 passenger door latch - NCRS Discussion Boards
  • Edward M.
    • January 10, 2014
    • 40
    Re: 67 passenger door latch
    Corvette America website, part# 4909 window crank removal tool.
    • Daniel Y.
      • September 30, 2002
      • 186
      Todd, as Ed said - its not that difficult. hardest part is fishing the retailing clip for the interior lock. you will need a hook. the rest is removable with a philips screw driver and the other tool as Ed had listed. once you get the door panel off and vapor barrier, you might be able to lube the latch well enough by reaching in. if that doesnt work you may need to remove it to properely lube everything . however, its a pain to get all the linkage back in place. but be patient.
      Dan Young
      65, 67 Duntov x2
      66 bowtie x 2
      71 LT1 TF
      90 ZR1 McCelland
      03 Anniverary
      06 Z06
        • 43281
        #18
        Ed-----
        Most auto parts stores as well as Harbor Freight also have this type tool. Very inexpensive.
        • Todd L.
          • August 26, 2008
          • 298
          #19
          Thank you guys. Ill let you know how it turns out when i do it
