Need a Source for 1968 LH Dash Pad not Remanufactured by Corvette America - NCRS Discussion Boards
  • Russ T.
    • May 31, 1989
    • 113
    I need to purchase a '68 LH dash pad with proper fitment, i.e., not one remanufactured by Corvette America.
    I've tried 2 of theirs and they simply won't fit, no matter how hard you "massage" them,
    and they are very expensive to boot. I can't take the frustration anymore.
    I first thought about Al Knoch, but he doesn't make them in the color that I need (dark blue).
    I could also try to find a decent original and dye or reskin it.
    Does anybody know any companies that remanufactures a 1968 pad that actually fits
    and can be installed in a reasonable amont of time without a grinder and a blowtorch ???
    Russ Trotter
    NCRS #15044
    • 11678
    Re: Need a Source for 1968 LH Dash Pad not Remanufactured by Corvette America
    EC Products?
    Corvette Pad Dash Lower Left 68 / 1968-1968 / ( #E6394 ) SHOWN IN 1968 DARK ORANGE LOWER LEFT HAND DASH PAD WITH OUT AIR CONDITIONING COMPLETE WITH ALL MOUNTING BRACKETS AND CLIPS ATTACHED. BELOW, NEXT TO "OPTIONS", CLICK ON ARROW TO VIEW COLOR SELECTIONS.
    • Edward J.
      • September 15, 2008
      • 6950
      Russ. have you tried looking around on Ebay, sometimes even Craigs list, if your lucky someone may be parting out a 68.
      • Russ T.
        • May 31, 1989
        • 113
        Addendum: Replacement of a 1968 LH Dash Pad ... From my experience the only currently acceptable solution is to purchase a mint original one off E-bay, dye it the color of your choice and then install.
        Repros were a horrible fit around the gauges and had a 3/8-in. gap at the lower RH corner where it joins the center cluster and shifter console. The original pad cost me as much as the repro, but it installed and fit perfectly on the first attempt. Until somebody manufactures a better fitting panel, this is the only way to go. Just my 2-cents.
        • Sal C.
          • December 1, 1984
          • 430
          Russ is correct. There are no reproduction dash pads, either upper or lower that fit correctly. But there is no shortage of people that will use them making nice restorable originals fairly easy to come by.
