396 fuel pump - NCRS Discussion Boards
396 fuel pump
  • David L.
    • July 31, 1980
    • 3310
    Re: 396 fuel pump
    Originally posted by Michael Hanson (4067)
    Sounds like there was no part number change for the fuel pump for the entire 65 model run.
    Michael,
    Hearsay tells me the fuel pump change was about May 1965.
    Dave
    • Michael H.
      • January 29, 2008
      • 7477
      Re: 396 fuel pump
      Originally posted by David Liukkonen (3775)
      Michael,
      Hearsay tell me the fuel pump change was about May 1965.
      Dave
      David,
      That may be difficult to document. If the 6415962 pump for 65 was still available in service until Aug of 67, I don't understand why it would have been replaced in production in May 65.
      Without a change shown in the AIM, I have doubts that it ever occurred.
      I know of one untouched 65 396 car that still has it's original 962 fuel pump and I think it's in the 20,000 VIN range.
      • David L.
        • July 31, 1980
        • 3310
        #18
        Re: 396 fuel pump
        Michael,
        I have to agree with you that it does not make any sense. Usually, but not always, when a part is changed on the assembly line it is also discontinued in the parts catalog. I do not know the difference between the 40248 pump and the 40366 pump. Apparently AC made a lot of 40248 (GM 6415962) pumps (1965 Corvette 396 only) so they must have put all the extras in the GM warehouse.
        Dave
        • Wayne M.
          • March 1, 1980
          • 6414
          #19
          Re: 396 fuel pump
          Just so the non-early BB guys know what is being discussed, here's a pic of an eBay original (needs rebuild), claims it's off a '66. Stamping on flange is AF40366. Can post a pic of stamping if needed.
          • Bill W.
            • March 1, 1980
            • 2000
            #20
            Re: 396 fuel pump
            Dave I have it clean but I'm not sure about where to look can you post a picture or send an email with a photo . pondpeoplel78@gmail.com
            • David L.
              • July 31, 1980
              • 3310
              #21
              Re: 396 fuel pump
              Wayne,
              IMO, the AF40366 pump would be dated January 1966.
              Dave
              • Wayne M.
                • March 1, 1980
                • 6414
                #22
                Re: 396 fuel pump
                Could somebody please explain the use of this 40366 fuel pump, with the curved tube at the inlet sump (rather than the NPT fitting with nipple) ?
                • Michael H.
                  • January 29, 2008
                  • 7477
                  #23
                  Re: 396 fuel pump
                  Wayne,
                  I suppose it was less expensive to form the lower housing out of one piece rather than a housing that required an additional inlet fitting. The attached tube would have been cheaper.
