396 fuel pump - NCRS Discussion Boards
396 fuel pump
  • Bill W.
    • March 1, 1980
    • 2000
    396 fuel pump
    I have the original fuel pump for my 396 . The last time it was started was in about 1980 and ran ok . Is there anyone who rebuilds the crimped 40366 pumps ? Is there a way to bench test mine ? If not who makes a good reproduction ?
  • Gary B.
    • July 31, 1979
    • 926
    Re: 396 fuel pump
    If you talk with Brian at Volunteer, Vette, he has somebody rebuild them. I just had two 40709's rebuilt, they look great. They have done several for me.
    Last time I posted this info, I was taken to task for spreading mis-information. But, they are being done, and I have had good luck with them
    Gary B
    • Timothy B.
      • April 30, 1983
      • 5186
      Re: 396 fuel pump
      Bill,
      Can you move the pump rocker arm in/out full motion and feel suction. If so, I would put it on the engine and try it but make sure to carry a fire extinguisher in the car. The crimp may look wet until the rubber diaphragm swells again because it's dried out but it may be fine.
      The person I was told that can overhaul these crimped pumps is Fred Ballard, Canyon Country, CA 661-251-2362. This is second hand information and I have not spoken to this man FWIW.
      • David L.
        • July 31, 1980
        • 3310
        Re: 396 fuel pump
        Bill,
        Is the stamped number on the pump just "40366" or is there additional letters (date code) on the stamping as well?
        Dave
        • Bill W.
          • March 1, 1980
          • 2000
          Re: 396 fuel pump
          Dave it looks like it is just 40366 stamped on the lower flange . It still has a lot of sludge on it . when I clean it I will let you know if its different .
          • Jim S.
            • March 13, 2013
            • 360
            Re: 396 fuel pump
            Bill,
            FWIW, I can vouch for Fred Ballard as someone you should talk to about rebuilding crimped fuel pumps.
            • Rick B.
              • April 11, 2010
              • 140
              Re: 396 fuel pump
              David, The date code, which i believe is two letters if i am not mistaken, how is that deciphered? Such as HG.............
              • David L.
                • July 31, 1980
                • 3310
                Re: 396 fuel pump
                Rick,
                IMO the "HG" = Aug. 1967. I have a lot of evidence but there are still nonbelievers (see link below). The 1964 and earlier AC fuel pumps did not have a date code in the stamping on the flange. The "early" 5-digit stamped crimped type AC fuel pumps also did not have the 2-letter date code.
                Dave
                https://www.forums.ncrs.org/showthre...380#post540380
                • Bill W.
                  • March 1, 1980
                  • 2000
                  Re: 396 fuel pump
                  Hi Dave . Mine is just 40366 it is the original from 65 BB # 17346. I will e mail a photo later tonight .
                  • David L.
                    • July 31, 1980
                    • 3310
                    Re: 396 fuel pump
                    Bill,
                    On your "40366" pump is there a "plain" hole above the threaded outlet with a casting year and radial hash marks? I have never had an assembly line 40366 pump. The rebuildable 4657 AC pumps have a "plain" hole above the threaded outlet that has a 2-digit casting year along with 1 to 12 radial hash marks which designate the month. You may need a magnifying glass and some Q-tips for cleaning purposes.
                    Dave
                    • Bill W.
                      • March 1, 1980
                      • 2000
                      Re: 396 fuel pump
                      I'll need to clean it better . answer wed.
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Re: 396 fuel pump
                        Originally posted by David Liukkonen (3775)
                        Bill,
                        Dave
                        Dave,
                        Are you sure the 40366 is the number for a 65 w/396 pump? That sounds like the number for 66 with 427. I'm pretty sure the 65 pump is not the same number as 66.
                        • Bill W.
                          • March 1, 1980
                          • 2000
                          Re: 396 fuel pump
                          The 396 used an early and a late pump . The 40366 was the second design . my car was build late May # 17346
                          • David L.
                            • July 31, 1980
                            • 3310
                            Re: 396 fuel pump
                            The 1965 AIM lists 6440248 as the fuel pump for the L78 (396). My 1965 Chevrolet Parts Catalog (May 1965) lists GM # 6415962 as the fuel pump part number for the 1965 Corvette (396).
                            AC 40248 = GM 6415962.
                            The 1966 AIM lists 6440366 as the fuel pump for the L36 & L72 (427). My 1966 Chevrolet Parts Catalog (Oct. 1965) lists GM # 6416245 as the 1966 Corvette (427)(exc. Sp./H/Per.) fuel pump part number and GM # 6415962 as the 1965 Corvette (396) fuel pump.
                            AC 40366 = 6416245
                            According to Chevrolet Parts History (for service parts, not assembly line parts) GM # 6415962 was replaced with GM # 6416245 in Aug. 1967.
                            I have no idea when the exact change took place on the assembly line where the 40248 pump was replaced with the 40366 pump but hearsay tells me it was about May 1965. The 396 first appeared sometime in the middle of the 1965 production (possibly March 1965).
                            Dave
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Re: 396 fuel pump
                              AC 40366 = 6416245
                              I have no idea when the change took place on the assembly line where the 40248 pump was replaced with the 40366 pump.
                              Dave
                              Sounds like there was no part number change for the fuel pump for the entire 65 model run.
