C2 - 1966 Trim tag - body sequence number question - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    On the trim tag...can the body "sequence number" be higher for a big block vs. small block?
    I would not think so, but I researching a potential car and I compaired it to my current car and one thing jumped out at me;
    Note: both cars are AO Smith bodies and both are coupes;
    1. car # 1 / VIN 13,5xx / Body build date G01 / Body sequence # A - 2624 (Big block car)
    2. car # 2 / VIN 14,2xx / Body build date G08 / Body sequence # A - 2602 (small block car)
    Is something wrong here or this normal?
    Any help would be appreciated, Dan
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: C2 - 1966 Trim tag - body sequence number question
    Let me take a stab. Since both the body build date code and the body sequence number are on the same tag, supposedly punched in at the same time, I don't see how a Feb 8th build date tag could have a lower body number than one built on Feb 01. Big or small block, or VIN sequence should have no bearing.
    Possibility that trim tag "puncher" (machine operator) made an error.
    • Daniel J.
      • July 29, 2007
      • 158
      Does anyone have photos of trim tags for AO Smith - coupe;
      between VIN 13,5xx (body build G01) and VIN 14,216 (body build G08)
      Photo or just the info of body sequence number & VIN would be helpful.
      Thanks, Dan
      FYI...I have already searched C2 registry.
      • Patrick B.
        • August 31, 1985
        • 2012
        Is one a coupe and the other a convertible?
        • Daniel J.
          • July 29, 2007
          • 158
          Both are coupes
          • Wayne W.
            • April 30, 1982
            • 3605
            It would be interesting to know what the body marks are on both bodies. It would tell more about the build sequence.
            • Daniel J.
              • July 29, 2007
              • 158
              Wayne: I am unsure of what "body marks" you are talking about?
              • Wayne W.
                • April 30, 1982
                • 3605
                http://forums.corvetteforum.com/members/19662005-365044-albums-mike-s-66-coupe-25715-picture-b137-on-underside-of-passenger-side-foolwell-bulkhead-area-109630.jpg
                • Louis C.
                  • September 30, 1988
                  • 80
                  AO Smith built vin 16,7XX Big Block Conv.
                  • Georges C.
                    • June 17, 2013
                    • 72
                    I have owned my car since Oct.14, 1976, knew the original owner -same high school, the second owner my best friend in high school who died Sept 1976 and I bought from his wife. My car is an AO Smith car A 3945 convertible. body build date of Jan. 20, 1966, Engine T0110ILH 437/390 build date Jan 10, 1966, final assembly St Louis Jan. 31, 1966 serial number 112419. I have the original Protect O Plate and matching tags.
