Changing antifreeze 1966 427 L36 - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    Re: Changing antifreeze 1966 427 L36
    that's my problem, I only have an 1 allenhead plug on the right side and on the left side I have 1 hex bolt. Something does not seem normal?
    • Richard M.
      • April 1, 1993
      • 198
      Harry, no problem you can just replace the 1 allenhead plug with a hex head plug, that's what the factory used originally.
      • Ronald L.
        • October 18, 2009
        • 3248
        Harry did you get them out?
        • Harry L.
          • December 22, 2008
          • 370
          Still waiting for parts. My project is changing the antifreeze, replacing the waterpump and replacing the hoses. It will be a fun Day or two. I have concerns about removing the drain plugs, I certainly do not want to break anything. I will spray lubricate around the the bolts before I give them a yank. Dutch
          • Harry L.
            • December 22, 2008
            • 370
            The bolt and the allenhead plug on the block do not seem that they want to break loose. It is almost to the point that I better leave them alone before I break something.I will work on installing the new waterpump and hoses. Dutch
            • Richard M.
              • April 1, 1993
              • 198
              Harry, Try Kroil or some other type of penetrating oil, it may take several days of application, but it should work.
              • Bill M.
                • April 1, 1977
                • 1386
                I thought of this thread while changing the coolant on my '67 L78, and took pictures of the block drain plugs. These are hex-headed and take a 9/16 socket. I remove the dipstick tube to make it easier to get to the passenger-side plug. (I also put a wad of paper towel in the tube so coolant doesn't get into the pan.)
                edit: There is a lot of coolant in the block. It is almost as much as in the radiator.
