1963 brake drum/ backing plate paint - NCRS Discussion Boards
  • Richard P.
    • September 29, 2011
    • 96
    Part of my brake job will be to clean and paint the drum and plate. Does this require a high temperature tolerant paint? My car is gently driven on short trips, less than 50 miles usually.
    Re: 1963 brake drum/ backing plate paint
    Richard -
    The drum exterior and spindle side of the backing plate didn't get any high-temperature paint - just ordinary black chassis paint, applied at Chevrolet-Warren.
    • Richard P.
      • 96
      Thanks John, I had a hunch that Chevy did it that way, both at Warren and St. Louis.
      • Alan D.
        • January 1, 2005
        • 2054
        Yes and Yes however caution here - if black you will get an 20% originality deduction. Couldn't help myself. End of comments.
        • Michael H.
          • January 29, 2008
          • 7477
          Alan,
          What would the deduction be for?
          • Michael G.
            • November 12, 2008
            • 2158
            The new JG calls for the standard backing plate and drum to be semi-gloss black.
            Mike
            1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
            1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
            • Michael H.
              • January 29, 2008
              • 7477
              Ok, thanks Mike. That's close. The entire brake/spindle assembly was coated with a form of chassis black for 63-64.
              Not the brake shoe side of the backing plate though.
              • Michael G.
                • November 12, 2008
                • 2158
                Mike
                • Richard P.
                  • 96
                  Thanks Alan, my car is, and probably always will be a driver. I try to remain faithful to originality as I do my maintenance but nothing short of a frame-off restoration would make this one suitable to be judged.
                  • Marco H.
                    • March 1, 2002
                    • 218
                    Sorry for digging up an older thread. Do I understand it correctly, that the brake/spindle assy was assembled bare (spindle, steering arm, backing plate with brake shoes installed, hub and brake drum) and then painted as an assembly? And therefore areas shielded by other parts did not receive coverage (area on backing plate behind spindle)?? This would mean that the wheel cylinder and shoe retainers were coated black as well, correct?
                    Any clarification is greatly appreciated.
                    Marco
