Rocker moulding screws and screw for front tab ??? Somethings wrong - NCRS Discussion Boards
    • 15646
    #31
    Re: Rocker moulding screws and screw for front tab ??? Somethings wrong
    Originally posted by Graeme Beaupeurt (48035)
    Come on guys, group hug.
    And we can all sing Kumbaya -- or however it is spelled. Better we should sing it -- I can't spell it.
    • Paul O.
      • August 31, 1990
      • 1716
      #32
      Originally posted by Doug Jorgensen (43687)
      Paul....Mine is an early built 1971 (Dec. 70) So I'm "thinking" that it is probaby and most likely, a cross recess screw.
      Thank you......Doug
      Doug
      I would agree with you my Sept 70 S/N 1914 built 1971 and a Jan 71 build S/N 67?? car both have that fastener type. Along with a few others I was involved with up to S/N 98?? had the same and now we have Dave S/N 16798 as a starting point to work back from. We now need more original cars to see when the change started to occur.
      Terry got it right kumbaya to all.
      • Ronald D.
        • March 11, 2012
        • 66
        #33
        My 1971 built late January 71 is all apart, so I took a look, it is exactly as the 3 photos with the J-nut
        • Bob I.
          • November 9, 2006
          • 265
          #34
          Originally posted by Mike Ernst (211)
          Apology accepted and appreciated. 70 #6243 has cross recess.
          Mike
          The cross recessed screw, is this a fillister head. Would the screw have a washer.
          Bob
          • Kevin G.
            • February 1, 2005
            • 1084
            #35
            1971 # 8555
            1972 #20942
              • 15646
              #36
              1971 # 8555
              1972 #20942
              The blue on the 1972 hex-head attracts my attention. IIRC in the early 1970s that blue was an indicator of a metric fastener. It was intended as a head-up to the mechanics to reach for their newly acquired metric tools.
              BTW: Very nice pictures Kevin.
                • 6960
                #37
                Terry, I believe that around 78/79 we started seeing the blue colored bolts and nuts from GM.
                  • 15646
                  #38
                  Terry, I believe that around 78/79 we started seeing the blue colored bolt and nuts from GM.
                  So if I am off by half a decade (and maybe I am), why is this one blue? Not defending my date estimate, only asking about the finish that looks out of place to me.
                  Maybe it is a lubricant or something else??
                    • 6960
                    #39
                    Terry, must kicked something up while driving??
                    • Kevin G.
                      • February 1, 2005
                      • 1084
                      #40
                      Drivers side,
                      • Rich C.
                        • January 1, 1994
                        • 383
                        #41
                        This fastener drove me crazy! It was one of the reasons I spent untold hours putting together a spread sheet that numerically ordered every piece of hardware for my '73 coupe. I went through EVERY page of my A.I.M., entering EVERY part #, then had computer arrange the #'s. ANYWAY, that screw # was used in two other places on my 73. 1) On the Valves In Receiver bracket. 2) The automatic transmission cable mounting and seal retainer. Sure enough, same finish and size. Awesome! Understandably the cross reference probably isn't foolproof, but at least this time it worked!
                        '73 LS-4 454, owned 23 years next month!
                        No L-88, but 395 ft/lbs. of torque!
                        • Dave S.
                          • August 31, 1992
                          • 2930
                          #42
                          Doug
                          We need much more data but with this limited sample it looks like the changeover from cross recess to hex was somewhere in the mid 1971 model year. Now we need to zero in.
                          Am I correct in thinking that no 70-72 cars used a nylon insert.????
                          • Randy C.
                            • March 1, 1985
                            • 154
                            #43
                            I checked my '71 #4001 with a build date of 12/15/70 and it has the same screw as '71 #8555.
                            Randy C.
                            • Michael M.
                              • November 1, 2004
                              • 64
                              #44
                              My '71 build date 2/2/71 #8417 is the same as Kevins '71 #8555.
                              Mike
                              • Paul O.
                                • August 31, 1990
                                • 1716
                                #45
                                Got a conformation on S/N 10608. a Feb 23 1971 car Pan head cross recess (Phillips) head type screw.
