FI modified as a tunnel ram on flea. Never saw one like this. - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: FI modified as a tunnel ram on flea. Never saw one like this.
    Originally posted by Jerry Gollnick (8575)
    WHOA!!!!!! Tell me more. Is this the answer to may latest list of challenges racing an FI unit? Do you have ANY details or a source I can track down? Jerry
    would it be legal for your racing ?? the only guy i know that is still alive that worked on the grand sport engines is ron mccafferty who ran the dyno lab at gulf and he is in calif some place.
    • Jerry G.
      • April 1, 1985
      • 1022
      I'm willing to argue the point. it's ridiculous to pull the race-car thousands of miles and get 1/2 a lap in a the cable breaks! I haven't talked to anyone who has an idea how to fix this problem. Apparently Gulf gave up on the cable also.
      • Clem Z.
        • January 1, 2006
        • 9427
        #18
        here is rons work on the dyno sheet. http://www.racingicons.com/gs/004/gulf.htm
        • Clem Z.
          • January 1, 2006
          • 9427
          #19
          i think you should try and convince them you should use a 600 CFM holley carb with the center pivot float bowls.
          • Dick W.
            • 10483
            #20
            Sho' had a very narrow power band, and dropped like a rock at 6,200 rpm's.
            Dick Whittington
            • Clem Z.
              • January 1, 2006
              • 9427
              #21
              i think it might have been a 370 inch motor and i don't think the FI even with dual air meters had enought air for that size engine.
              • Dick W.
                • 10483
                #22
                It was definitely running out of air or cam
                Dick Whittington
                • Sal C.
                  • December 1, 1984
                  • 430
                  #23
                  Quite a few drag racers in the late '60s early '70s experimented with modifying FI units because of their desirable "ram" effect. One that I raced with, Ralph Ridgeway, was one of the more successful to do so. He developed the "Ridge Runner" which was made in Rockville CT.
                  • Jerry G.
                    • April 1, 1985
                    • 1022
                    #24
                    Anybody have a better photo of the distributor mounted fuel pump shown in Clem's photo
                    • Mike M.
                      • May 31, 1974
                      • 8382
                      #25
                      clem: is the white midyear behind the gulf research sbc the one that dr blatchley bought from grady et al? donald blatchely had a white 66 big block roadster . thanks,mike
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        #26
                        mike i do not know as i did not take the picture. i believe that picture was taken at the don yenko estate sale.
                        • Steven B.
                          • June 30, 1982
                          • 3986
                          #27
                          Mike, after enlarging the photo the car looks like Milano Maroon with a white nose and two gold or yellow stripes. Steve
                          • Tom P.
                            • April 1, 1980
                            • 1814
                            #28
                            This is the Gulf Oil unit that John Eyestone had for sale some years back.
                            And on a Cheetah.
                            Modified thumb tack valve for a dual air meter unit.
                            Early unit with dual side mount air meters (many of you know this unit).
                            • Roger W.
                              • January 29, 2008
                              • 567
                              #29
                              Back in the early 60's there was a speed shop "Dyno Tune By Deb" in Springfield, MA that modified a Corvette F I manifold to use with a carburator and got very good results. There was big article in the local paper about it.
                              • Jerry G.
                                • April 1, 1985
                                • 1022
                                #30
                                Tom. Do you know the source of the drawing (thumbtack)that you included. Do you know the intent of this modification? Jerry
