Bolts - NCRS Discussion Boards
Bolts
  • Gary B.
    • February 1, 1997
    • 7053
    Re: Bolts
    Thank you Gary!
    Now to find a source for these. I'm surprised these are not grade 5 or 8 bolts. CC sells grade 5 with different head markings for this application.
    AIM lists PN 100161. Is there a reference that provides the specs given the PN?
    David Bartush provides the specs for 100161 in post #10.
    Gary
    • David B.
      • March 1, 1980
      • 689
      Re: Bolts
      The '63 AIM Section 7 B2.00 lists the possible usage of 2 different type bolts. If you have #100161 it is plain 1/2-13 x 1 3/4 GM 260-M if you have #9417294 it is cad plated 1/2-13 x 1 3/4 GM 280-M. Take your pick which set you have. These are GM specs.
      I looked at that forum and it appears they are a little confused.
      • Mark E.
        • April 1, 1993
        • 4602
        #18
        Re: Bolts
        Thanks again David!
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Gary B.
          • February 1, 1997
          • 7053
          #19
          Re: Bolts
            • 11669
            #20
            Re: Bolts
            Originally posted by Gary Beaupre (28818)
            ...to replace the incorrect zinc plated bolts I purchased from either Paragon or LIC. This is another case of the catalog companies selling a zinc plated repro fastener instead of the unplated original, which is common for many transmission and shifter-related bolts. I suspect the repro parts companies don’t want to keep unplated bolts in inventory that might rust before being sold.
            Gary
            It's not just transmission and shifter bolts; those happen to be your area of interest.
            I de-zinc and then phosphate a lot of bolts, nuts, washers and studs going onto Corvettes.
            It's not just inventory rusting, but most owners (NCRS is a small crowd) don't care about the finish other than not wanting to see rust months after installation.
            • Gary B.
              • February 1, 1997
              • 7053
              #21
              Re: Bolts
              Patrick,
              The items numbered 2,3,4,6,7,8,9, that typically include a quantity of more than one of each, comes to a combined total of 22 pieces. None of those 22 items was originally zinc plated. If you buy those 22 items from Paragon today, they all come zinc plated.
              Gary
