Bolts - NCRS Discussion Boards
Bolts
  • Morris R.
    • May 7, 2012
    • 213
    Bolts
    Does anyone know the correct bolts that should be used in bolting a muncie m20 transmission to the bellhousing and the bolts used to bolt the bellhousing to the motor? (327/350hp)
    i have 6 bolts marked "m" on the heads for the transmission to the bellhousing i'm not sure if that is right and not sure with the ones i have for the bellhousing (4) to the motor, the headmarks are "le" can someone please clear this up?
    Thank you
    • 43247
    Re: Bolts
    Thank you
    Morris-----
    The bellhousing-to-block bolts were flanged head, 3/8-16 X 1-1/4", zinc plated with untrimmed ("indented") head and GM 280-M material (3 radial ines). I believe "M" was a common headmarking as were "A" and "C".
    The transmission-to-bellhousing bolts were 1/2-13 X 1-3/4", zinc plated with trimmed ("non-indented") head and of GM-280M material. I think that "TR" was a common headmarking as were "A" and "P".
    • Morris R.
      • May 7, 2012
      • 213
      Re: Bolts
      Joe did you ever see "le" bolts? Could they be correct for the transmission to bellhousing? Thank you for replying
        • 43247
        Re: Bolts
        Morris-----
        Vaguely, I seem to recall seeing "LE" headmarked bolts as common hardware store bolts. However, I suppose it's possible that such headmarked bolts were originally used. If the bolts you have show any evidence of chromate overplate (i.e. "gold" coloring), then they are definitely not original.
        • Gary B.
          • February 1, 1997
          • 7053
          Re: Bolts
          Morris,
          Attached are notes and a sketch of those original bolts from my '66 L79.
          Gary
            Re: Bolts
            Maury -
            "LE" headmarked bolts were made by the Lake Erie Screw Company, but I don't recall ever seeing that headmark on transmission bolts. There are (4) transmission-to-bellhousing bolts, and (6) bellhousing-to-block bolts.
            • Morris R.
              • May 7, 2012
              • 213
              Re: Bolts
              Thank you everyone big help
              • Mark E.
                • April 1, 1993
                • 4600
                Re: Bolts
                Originally posted by Gary Beaupre (28818)
                Morris,
                Gary
                [ATTACH=CONFIG]43408[/ATTACH]
                Are the 4 bolts attaching the Muncie case to the bell housing really zinc plated with no grade marking?
                What grade are these bolts?
                Same bolts for small block and big block?
                My 1970 454 has 3 black phosphate grade 8 bolts (with two different markings) and 1 grade 5 zinc bolt, so I want to sort this out.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Gary B.
                  • February 1, 1997
                  • 7053
                  • David B.
                    • March 1, 1980
                    • 689
                    Re: Bolts
                    If you would provide a part number for these bolts a lot of your question could probably be answered correctly. The '71 4 speed bolts are listed as
                    # 100161 if the same as '70 these are plain 1/2-13 x 1 3/4 grade GM 260-M.
                      • 11668
                      Re: Bolts
                      10 years later you resurrect this?
                      • Gary B.
                        • February 1, 1997
                        • 7053
                        • Mark E.
                          • April 1, 1993
                          • 4600
                          Re: Bolts
                          [ATTACH=CONFIG]117233[/ATTACH]
                          Thank you Gary!
                          Now to find a source for these. I'm surprised these are not grade 5 or 8 bolts. CC sells grade 5 with different head markings for this application.
                          AIM lists PN 100161. Is there a reference that provides the specs given the PN?
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Mark E.
                            • April 1, 1993
                            • 4600
                            Re: Bolts
                            Yes, I researched my question and found this thread addressing the same question. To avoid a new thread on the same topic I posted here.
                            Would a new thread with a link here be preferred?
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                            • Mark E.
                              • April 1, 1993
                              • 4600
                              Re: Bolts
                              Thank you Gary!
                              I found this thread on CF answering my question.
                              https://www.corvetteforum.com/forums...op-manual.html
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
