More Black- Battery compartment/jack storage bin? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    #31
    Re: More Black- Battery compartment/jack storage bin?
    Originally posted by Reba Whittington (8804)
    Patrick, here is a photo of the compartment insulation with the bin removed.
    [ATTACH=CONFIG]42699[/ATTACH]
    Perfect, thanks for the pic. Usually I can piece together what the car had as some evidence remains-the former owner and/or mice must have stripped this clean.
    Thanks again!
    Pat
    • John C.
      • January 1, 2005
      • 616
      #32
      Paul
      My car was built in mid April. I don't know exactly when the configuration changed. It's really hard to remove the straight front bins as you have to struggle to get the front lip over the latch catch.
      John
      • Reba W.
        • 938
        #33
        What is the build date of your car, Patrick?
        Here is the statement from the JG:
        Beginning SN 9315 in 1968, aluminum-foil-backed fiberglass insulation (foil toward outside) is found in the battery and passenger's side compartments. It was recommended in a Dealer Technical Service Bulletin on April 22, 1968, for complaints of excessive heat in the passenger compartment. It disappeared in 1969.
          • 15621
          #34
          Pat,
          My search only yielded this:
          https://www.forums.ncrs.org/showthre...k+storage+tray
          Not exactly what I was looking for.
