Hi,
I have an '71 LS5 Coupe, and was convinced by my mechanic that since we have done so much already (including a rebuilt engine), that we should go ahead and replace the fuel and brake lines. Before I knew it, I had purchased all new pre-bent lines and had cut off the old lines. It's been 6 months and the project has been stalled for various reasons, one of which is that neither my mechanic or me are certain on how to fully access all of the bolts/mounts, and also how we should lift the body.
We need to get this project back on track.
I've already begun spraying (with Kroil) the tops of the bolts I can get at without removing any housings.
I have read many archived posts here. I now realize that to access the underside of #3 and #7 bolts/mounts, one may need to cut off the fiberglass end caps on the frame.
My Questions are:
-What other panels/housings need to be removed for access to all the other body mount bolts/nuts?
Does one need in every case to buy new housings/rivets? (Hope I'm using the right terminology)
-Should we just lift one side at a time, as I've read many seem to do when not wanting or needing to go with a full body off resto? Is this safe for the existing and nice paint job on the body? (We have no way to lift other than floor jacks.)
The car is to be a very nice, mostly factory correct driver.
Thanks in advance for any help.
Jon
My Questions are:
Jon
