T3 headlights - NCRS Discussion Boards
T3 headlights
  • Morris R.
    • May 7, 2012
    • 213
    T3 headlights
    I'm looking to buy a set of t3 headlights. My question is are the reproduction of t3 oem judge worthy by ncrs standards? Your insight is appreciated.
  • Michael M.
    • February 1, 1993
    • 604
    Re: T3 headlights
    Morris, the reproduction T-3 headlamps have a DOT symbol that the judges look for. NCRS standards are NON-DOT for T-3 headlamps.
    • Morris R.
      • May 7, 2012
      • 213
      Re: T3 headlights
      Hi michael, where would the dot be located?
      • Page C.
        • February 1, 1979
        • 802
        Re: T3 headlights
        1953-1973 model years do not have DOT markings on headlights. There is a 3 point deduct per car for a full set. See Judging Reference Manual page 31.
        Page Campbell
        • Morris R.
          • May 7, 2012
          • 213
          Re: T3 headlights
          Where would the dot be on the reproductins?
          • Dave S.
            • August 31, 1992
            • 2925
            Re: T3 headlights
            Morris,
            The earlier reproductions had DOT embossed on the clear glass and was visible to the judges. The newer reproductions have the DOT on the back of the lens and out of sight to the judges. With that change the only way to differientate is the configuration of the filament itself.
            • Russ S.
              • April 30, 1982
              • 2162
              Re: T3 headlights
              I saw a set of NOS T3s on Ebay go for $500. Some one wanted them badly.
              • Pat M.
                • April 1, 2006
                • 1575
                Re: T3 headlights
                Morris, check out this previous thread wherein I posted a pic of the tiny DOT mark (apparently the earlier repos based on Dave's comments) in the #7 post:
                https://www.forums.ncrs.org/showthre...ation&uid=4048
                • Morris R.
                  • May 7, 2012
                  • 213
                  Re: T3 headlights
                  Do you think it will pass ncrs judging?
                  • Brian M.
                    • February 1, 1997
                    • 1839
                    Re: T3 headlights
                    They are worth a 3pt deduct if that still applies. At least you can see at night. JMHO. BTW do they pass the brightness test during PV?
                    • Pat M.
                      • April 1, 2006
                      • 1575
                      Re: T3 headlights
                      Morris, if you're asking me, and if by "pass" you mean did it draw no deducts, the answer is "no". My earlier repos drew a 3 point deduct each time through multiple judgings. But as noted above, they are nice and bright for night driving, and are far less likely to fail during Operations Flight judging, which failures draw large (I think 25 points) deducts.
                      My repos did.
                        Re: T3 headlights
                        Maury -
                        Forget original T-3's - they're about like kerosene lanterns in terms of brightness compared to more modern conventional headlights, and T-3's are 50 years old and are highly prone to failure (which is a 25-point hit in Operations judging). A full set of reproduction T-3's (made by Wagner Electric) are bright, reliable, and are only a 3-point deduction in Flight judging.
                        • Morris R.
                          • May 7, 2012
                          • 213
                          Re: T3 headlights
                          Thank you pat
                          • Morris R.
                            • May 7, 2012
                            • 213
                            Re: T3 headlights
                            Thanks to everyone that responded, the replies were a big help.
                            • Clark K.
                              • January 12, 2009
                              • 536
                              Re: T3 headlights
                              Page Campbell
                              I am looking at page 31 of my copy of the 1953-1993 Corvette Judging Reference Manual (7th Edition) and there is no statements about headlights. Perhaps you meant the '66 Judging Guide?
                              My '65 has the reproduction T3 headlights. I looked at my most recent judging sheet and the sheet (section 12 Headlight Area) states that there is a 3 points per bulb deduction. However, the exterior judging team deducted only 3 points for my four headlights. Can anyone explain the confusion?
                              -Clark
