Re: T3 headlights
In this case, the car should be DISQUALIFIED if DOT marked beams are detected. Neither intensity nor light color should need to be evaluated since DOT mandates that beams supply a minimum amount of lumens, and LL beams must comply with this. LL states that their beams supply about 25% more brightness, as stated above in post #25. Reading the PV Test Guide and interpreting literally, means that a car having detectible Lectric Limited replacement beams shall be immediately disqualified. Excerpt from p6 of Second Edition 1963-1967 Ops Manual/PV Test Guide:
Two tests are to be used which determine if an alteration from original config. will disqualify a car. Acceptable equip. meets BOTH the following:
1. Does not provide an operational advantage or enhancement to the designed function of the vehicle.
2. Does not result in a different mode of operation or provide a different result than would be expected from the original part.
The Corvette must be equipped with bias ply tires. Other types, such as radials, would disqualify the car...................................
