D98 pin stripe option - NCRS Discussion Boards
    • 43213
    #46
    Re: D98 pin stripe option
    She's correct. It's a B.
    Compare it to the UU8 just below and to the right (or to MD8 or NB1). Enlarge your screenshot if needed.
    It be B.
    Patrick------
    I did all of those things you mentioned before I posted. I even used a magnifying glass to further examine the enlarged image. It appears to me that both sides of both loops are ROUNDED.
    In addition, I cannot find any "D8B" code applicable to a 1984 Corvette. It's possible there was such a code but I can find no record of it.
    ADDENDUM:
    I did find a "D9B" code for a 1984 Corvette. It applies to a speed sensor for cars equipped with 3.07:1 axle ratio. So, if this car has a 3.07:1 axle ratio then the "D9B" code would apply. Regardless, my opinion on the last character of the code has not changed. It still appears to be an "8" to me.
    • Pat M.
      • April 1, 2006
      • 1575
      #47
      Joe - I will only add this - don't you know the wife is always right?
      Seriously, it does appear to be a "B" to me, but WTFDIK.
        • 43213
        #48
        Pat------
        Well, if it is "D8B" I hope he never needs a speed sensor. The GM piece, GM #25007339, is discontinued and it's not available in the automotive replacement aftermarket.
        • Pat M.
          • April 1, 2006
          • 1575
          #49
          Joe, to me it looks like D9B. As Patrick Hulst said, the last digit looks like a "B" to me, unlike the lower "UU8" code. If we're correct, what would D9B indicate?
            • 43213
            #50
            Patrick------
            A code for the speed sensor used for cars with 3.07:1 rear axle ratio.
            • Kenneth B.
              • August 31, 1984
              • 2087
              #51
              Looks just like B in BSC/CL at the bottom & not like the UU8
              • Rick A.
                • July 31, 2002
                • 2147
                #52
                Compare the BGR and the D9B - the "B" in both sure look the same to me
                Rick Aleshire
                2016 Ebony C7R Z06 "ROSA"
