C1 Battery J bolt needed - NCRS Discussion Boards
  • Dick W.
    • 10483
    #31
    Re: C1 Battery J bolt needed
    You are closer to 135 degrees than 90
    Dick Whittington
    • Philip P.
      • February 28, 2011
      • 558
      #32
      I guess it is how you look at it..... left-right-upside down or right side up.
      • Wayne S.
        • August 31, 2003
        • 34
        #33
        Thanks for the picture Bill. I hope we get some more response from other C1 "nail head" bolt owners. This is very interesting.
        Wayne
        • Keith R.
          • August 31, 2001
          • 660
          #34
          Originally posted by Wayne Sullivan (40646)
          Hi Roger,
          I checked my molding a little closer and I think what you are seeing that makes you think the molding is off is actually the underside of the fender. It could be off 1/16th of an inch at the very front. When looking straight at it, it's not noticible, but from a bit of an angle, you see the inside of the fender well. It's such a small amount, I could probably fix it pretty easily. This is original molding. It was dinged up so I sent it to Bob Mayle in NY and he removed all the dents and dings and buffed it to perfection. All 4 peices were $160 and it's original. His e-mail address is ssnybob@cs.com (phone 716-683-4018) I've attached some add'l pictures. Hope that helps.[ATTACH=CONFIG]38550[/ATTACH][ATTACH=CONFIG]38551[/ATTACH][ATTACH=CONFIG]38552[/ATTACH]
          Wayne
          Mine fit the same way on the passenger side and I thought it was the trim piece so I got another NOS piece and it fit the same way. There was discussion on the Board recently regarding this and I think that the conclusion was that the fit was not that precise. I noticed that trim on a number of other cars at the Tucson regional fit the same way. Al Edmonds had a thread on this recently as well. You might run a search for his posts.
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          2013 427 Convertible
          Shade tree mechanic and
          B-52 pilot extraordinaire
          • Stephen B.
            • August 31, 1992
            • 261
            #35
            Hi Dick
            Can you tell me what the radius is on the inside of the hook ?
            Stephen Barrett
            59,66,71,73
            • Philip P.
              • February 28, 2011
              • 558
              #36
              I was reading my Judging guide and on page 68 they call it a 5/16 bolt size it sure looks like 1/4 inch to me. Is this an error.
              • Thomas H.
                • August 31, 2005
                • 1058
                #37
                I took the hold down bolt out of my 60, which I believe is original to the car and made a detail drawing of it. Measurements were made with dial calipers but I'm sure there were manufacturing tolerances so don't consider what I have measured to be absolute, more of a reference. Definitly 5/16-18 thread.
                Tom
                2007 Z06, Lemans Blue
                • Wayne S.
                  • August 31, 2003
                  • 34
                  #38
                  Sorry, I don' t know.
                  Wayne
                  • Wayne S.
                    • August 31, 2003
                    • 34
                    #39
                    Good job Tom.
                    Wayne
                    • Wayne S.
                      • August 31, 2003
                      • 34
                      #40
                      I'm pretty certain it is 5/16.
                      Wayne
                      • Philip P.
                        • February 28, 2011
                        • 558
                        #41
                        Tom, Great information it will be interesting to see what the reproductions I ordered look like.
                        Phil
                        • Dick W.
                          • 10483
                          #42
                          Tom
                          [ATTACH=CONFIG]38582[/ATTACH][ATTACH=CONFIG]38583[/ATTACH]
                          So nice to have a draftsman on the TDB. Even an old phart like me can understand that print.
                          Dick Whittington
                          • Bill M.
                            • April 1, 1977
                            • 1386
                            #43
                            Tom
                            I checked the original j-bolt from my '59 and got the same dimensions as Tom's drawing for overall length, hook length, hook angle, and thread (5/16-18) length.
                            • Wayne S.
                              • August 31, 2003
                              • 34
                              #44
                              Thank you Sir.
                              Wayne
                              • Roger W.
                                • January 29, 2008
                                • 567
                                #45
                                Your second photo looking straight on does look much better. My space between the molding and the fender lip is about twice as much as yours.
