Lectric Limited Plug Wires - NCRS Discussion Boards
  • George J.
    • March 1, 1999
    • 775
    Re: Lectric Limited Plug Wires
    After adjusting my valves, I couldn't get the car to run right. I suspected the wires, and finally changed them. Bingo, car runs better than it has in years. No hesitation, no intermittent misses. Those dated wires are junk. I just wish someone made better quality wires with the FI 90 degree ends. John H. recommended I check with a company and have just not gotten around to it.
    George
    31887
    • Loren L.
      • April 30, 1976
      • 4104
      Mike, is that the same St Bernard that has the two containers of J.B.
      Weld on his collar?
        • May 31, 1974
        • 8388
        Weld on his collar?
        smart ass! regards,mike
          • May 31, 1974
          • 8388
          Originally posted by William Clupper (618)
          Years ago, LL was able to purchase cable very similar to the original from the OEM source. That source discontinued that business a few years ago, and that may be the root of some of the problems seen today. Mikes approach is great as long as you don't plan on using the Radio.
          clup: Real corvettes don't have radios. and Real corvette drivers sing "Momma Hate Diesels" to entertain themselves while motoring. regards,mike
          • Ken A.
            • July 31, 1986
            • 929
            Actually, Bill, I can still get you any Packard wire you wish-the rolls are pretty long @25,000 feet. We're starting to test a low ohms/foot (100) Packard set for the small blocks next week that is a supression wire & will look OE except tha the date codes will not be available. Ken
            • Ed M.
              • August 31, 1988
              • 59
              My 66 390 coupe breaks up on WOT and the cause was the No. 3 cylinder wire leaking voltage. I have talked to Lectric Limited in the past and I assume they won't stand behind their product. I don't want an entire set just a replacement for the No. 3 wire. Then off they come until the next flight judging. Has anyone had any luck getting LL to replace faulty products?
              Ed
              • John F.
                • March 23, 2008
                • 2409
                Wondering?? Has anyone ever called and talked to owners of LL? One would think with all the complaints they would regroup with a good set of wires and we would all buy a good set that met judging standards.
                • Don L.
                  • August 31, 2005
                  • 1005
                  FWIW, my LL wires (1972 SB 4 spd) have performed without issue since installation in 2009 (approx 3,000 miles ago).
                  Wonder when the change was made @ LL?
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Al R.
                    • June 30, 1988
                    • 687
                    #24
                    I've got a set I bought back around 93-94 and have not used. Would these fall into the good range hopefully? What 'd ya'll think?
                      • May 31, 1974
                      • 8388
                      #25
                      my first encounter with defective LL plug wires was in about 1990 when i restored my white 57 FI so i'd guess your 93-94 wires are problematic. mike
                      • Michael G.
                        • November 12, 2008
                        • 2157
                        #26
                        Even with LL wires, the AM radio in my car sounds worse than the mail order crystal set I constructed when I was five....
                        During ops, I was surprised when it actually found a station, any station, and played half of what I think was "Angle Baby". I'd welcome stainless steel wires, at least I'd be able to identify the clicks
                        Mike
                        • Dan T.
                          • March 1, 1979
                          • 42
                          #27
                          You guys scare me. I just purchased a new set from LL. I have not put them in the car yet, sounds like I better get a different set of wires. Is there anyone who makes a good set that will last?
                          Dan Termeer
                          1966 coupe 427/435HP
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            #28
                            For my 2 cents worth; I too put on LL dated wires on my 63 SHP back in the mid 90's (you know, the ones that wrap around everything in sight on the sides of the engine). Mine have performed very well since, pulling redline w/o any misses anytime. I used to use Packard 440 wires back in the day, but the neighbors complained I messed up their TV reception, which made it hard to sneak home after midnight. Besides, I spent good money on a nice sound system and want to enjoy it. My two uncompromised aftermarket add ons are my sound system and my electronic ignition conversion. Won't ever change either of them.
                            Stu Fox
                            • Larry M.
                              • January 1, 1992
                              • 2694
                              #29
                              My LL set (small block with 1Q67 date) was purchased around 1996-97. They have performed well, with no issues to date.
                              Larry
                              • Jeff A.
                                • January 1, 2000
                                • 312
                                #30
                                I have LL wires on my cars - never had a problem- EVER
                                Realistically, I don't drive the cars that often, and I haven't had to mess with the wires once they were installed. So as a rule once you install them - leave them alone and you should not have any issues.
                                After reading the posts here - If you need to remove them I would say you should do it CAREFULLY....
                                My Cars
