3X2 Fuel line brass T-blocks - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    For a '69, can someone tell me how to tell reproductions from originals?
  • Mark D.
    1984-96 Team Leader
    • June 30, 1988
    • 2157
    Re: 3X2 Fuel line brass T-blocks
    Originals have Weatherhead logos stamped in.
    Kramden
    • Patrick N.
      • March 10, 2008
      • 954
      Originals have a "W" repeated on the blocks- repos do not. USA corvettes - advertised in Drive line has originals.
      Pat
      • Dick W.
        • 10483
        This is the Weatherhead logo. I have seen some repros with just a plain W on them.
        Sorry about the quality of the photo, when I enlarged it, I found it was slightly out of focus.
        Dick Whittington
        • Wayne M.
          • March 1, 1980
          • 6414
          Dick -- here's 2 shots off a late '69 fuel block. The second junction block was so faint all you could see was the outside imprint of one side of the row of hexagons.
          • Patrick N.
            • March 10, 2008
            • 954
            Same logo on the ones I have as well. I also noticed the same logo on the brake line blocks.
            • Dick W.
              • 10483
              The W, with the arrow thru it, inside the octagon pretty much seals the real deal
              Dick Whittington
              • G A.
                • February 18, 2010
                • 229
                OK. Thanks gentlemen. Will the repop fuel lines seat in the original blocks?
                • Dick W.
                  • 10483
                  That should be no problem. The tubing flare should be the same.
                  Dick Whittington
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    as long as you don't use stainless steel lines because if the flare is not correct it will eat into the brass fitting and maybe leak. with SS lines i used a steel fitting to preform the line flare before installing it in the brass fitting and this may be a good idea even with plain steel lines
                    • G A.
                      • February 18, 2010
                      • 229
                      Thanks. I've got the plain ol' steel lines. Clem, what exactly are you referring to as a steel fitting re preforming the line, if you don't mind educating me.
                      Dan
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        Dan
                        holley carb center pivot float bowls use a steel inverted flare fitting for the fuel line and i use one of those held in a bench vise to tighten the line into to form the flare on the line before putting them in to a brass fitting.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          http://www.holley.com/26-26.asp
                          • G A.
                            • February 18, 2010
                            • 229
                            Ahh.. nice and simple. Thanks!!
                            Dan
                              • 15616
                              I know that fitting should be steel, and on many of the 1969 & 1970 Holleys I have seen it is plated black -- but that picture sure looks like brass.
