Thread Repair Holley Fuel Bowl - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5197
    Re: Thread Repair Holley Fuel Bowl
    Thanks Dick and Clem,
    As soon as the camera batteries charge I will post a picture showing the condition of the threads.
    There is approx 1/4" of good thread inside that's perfect but I don't think there is a longer fitting that will work with this bowl..
    • Clem Z.
      • January 1, 2006
      • 9427
      did you check with any of the carb rebuilder to see if they have the the special helicoil ??
      • Timothy B.
        • April 30, 1983
        • 5197
        #18
        Here are some pics of the bowl showing the bad threads. I am concerned about the indent in the bowl that may cause the drill bit to go through the side,(last pic).
        It's a shame I can't find a longer attachment screw because the threads below are pristine as is the rest of the bowl. This bowl has the little roof and eye features found only on the early 2818 bowl.
        • Gary B.
          • September 30, 1987
          • 305
          #19
          After looking at your photos I like Dick's idea.
          If there are a few threads still left, I have used Loctite Form-A-Thread to repair carb inlet fittings. I know, the last time I posted this I got shot down in flames, but it does work with no leaks. I know of one repair on a daily driver that was done over 10 years ago and still does not leak. We used it to salvage several valuable carburetor bodies and fuel bowls. It is a high strength epoxy with a release agent that you apply to the threads. Once the epoxy sets up, you can remove and replace the fitting
          If you use it, follow the instructions to the letter for good results.
          • Dick W.
            • 10483
            #20
            From the picture, I believe the Loctite Thread Repair would work
            Dick Whittington
            • Clem Z.
              • January 1, 2006
              • 9427
              #21
              any good machine shop can make a new longer threaded brass part if the cost is not a problem.
              • Dick W.
                • 10483
                #22
                If you use a longer threaded part, you stand the chance of restricting fuel flow.
                Dick Whittington
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  #23
                  once the brass piece was installed and tightened in the bowl with the fittting you could mark the location remove the brass piece and drill a hole thru the threaded part to line up the the passage to the secondary bowl for fuel flow. if he uses your idea he should check to make sure the epoxy is ethanol proof.
                  • Dick W.
                    • 10483
                    #24
                    Apparently it is as there are several drivers around here that have had the epoxy fix. It is a lot easier to fix a quadrajunk with epoxy than it is to install one of the repair kits. And besides, it looks a whole lot better
                    Dick Whittington
                    • Timothy B.
                      • April 30, 1983
                      • 5197
                      #25
                      Dick,
                      Is this Locktite product available in auto parts stores or home depot?
                      It's probably the best approach and if I am not happy I can persue the helicoil idea. I am going to the machine shop just to see if they have a helicoil.
                      After I finish I will post some pics for everyone.
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        #26
                        Dick,
                        i looked thru the whole helicoil catalog and they list no 9/16-24 insert
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          #27
                          Dick,
                          the loctite product is part # 37390
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            #28
                            Dick,
                            Timothy,
                            Wouldn't it be a lot easier and a LOT safer to just find a new or good used bowl? These things can't be hard to find and you would never feel comfortible driving around knowing a gob of Locktite is all that's between you and a dandy blaze if the fitting pops out while driving.
                              • April 1, 2000
                              • 477
                              #29
                              Assuming procuring another bowl is a problem...and looking at the pics and how nice the threads are just a bit deeper...I really like this idea. If you have a vocational high school or college close that has machine shop equipment/classes, you could probably even get one made cheap as a special project. As Dick/Clem point out, you may need to drill a hole to ensure adequate flow.
                              • Dick W.
                                • 10483
                                #30
                                Tim, my local Fastenal had it in stock.
                                Dick Whittington
