Thread Repair Holley Fuel Bowl - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5202
    Can someone tell me the correct size thread for a 2818 Holley inlet fitting. I have a stripped thread to repair if the helicoil is available somewhere.
    The bowl is the original and in V/G condition other than this problem..
  • Ken A.
    • July 31, 1986
    • 929
    Re: Thread Repair Holley Fuel Bowl
    Not worth the effort. Call Holley & buy another bowl.
    • Clem Z.
      • January 1, 2006
      • 9427
      most places that do heli coil float bowls don't do holleys because there is not enought material to make it work. the thread is 7/8"-20
      • John D.
        • December 1, 1979
        • 5507
        Heli-coil makes a 7/80-20 carb kit. Ready for price Tim???
        288.42 plus. Whew!!! Would not be worth it unless you are in the business. Doubt if it would even work on a Holley though but might work on other carbs.
        I see fuel injections with stripped out inlet fittings.
        Tip: Say you don't need a heli-coil and just want to chase some messed up threads. You need a special tap for fuel.
        Fuel Injection example since I don't work on carbs anymore.
        The inlet fitting on a typical(all) 57 to 65 is a 1/8" pipe thread. But that's not really correct as it's a 1/8 straight pipe thread. I have the numbers of the tap in the shop if anyone wants it. The inlet fitting itself is 1/8 tapered. So you screw a tapered fitting into a straight pipe thread for a crush fit. Go beyond that and you break the castings.
        Best thing to do with the carbs and FI's that have issues on the inlet is to replace the castings. JD
        • Timothy B.
          • April 30, 1983
          • 5202
          OUCH!! $288.
          Are you guys sure the thread size is 7/8x20, this is not my 3810 with the big fitting but the smaller banjo type fitting with smaller inlet threads for the 2818 holley.
          • Clem Z.
            • January 1, 2006
            • 9427
            OUCH!! $288.
            a picture will help to see what you are referring to.
            • Clem Z.
              • January 1, 2006
              • 9427
              the only other size i can find for holley carb float bowls is 9/16-24 for side hung float bowls
                • 15634
                I am pretty sure that is what he is talking about on the 2818. My LT1 Holley with the cathedral center hung bowls takes the 7/8 inch fitting.
                • Dick W.
                  • 10483
                  LeMans bowls??
                  Dick Whittington
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    LeMans bowls??
                    i had a set of them and they use a NTP fitting
                    • Timothy B.
                      • April 30, 1983
                      • 5202
                      Thanks everyone, 9/16"-24 sounds about right. Are these sizes, (7/8-20, 9/16-24) the only two sizes used on the Holley?
                      How difficult is the 9/16-24 helicoil to find..
                      • Dick W.
                        • 10483
                        I have a set also, but did not want to dig them out of who knows where they are to see which thread they had
                        Dick Whittington
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          they used to bring $800 for the pair on e bay. i sold mine as the counterfeit cobra guys want them for on the FE ford 427 engines
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            i have not found it listed anyplace
                            • Dick W.
                              • 10483
                              If there are a few threads still left, I have used Loctite Form-A-Thread to repair carb inlet fittings. I know, the last time I posted this I got shot down in flames, but it does work with no leaks. I know of one repair on a daily driver that was done over 10 years ago and still does not leak. We used it to salvage several valuable carburetor bodies and fuel bowls. It is a high strength epoxy with a release agent that you apply to the threads. Once the epoxy sets up, you can remove and replace the fitting
                              If you use it, follow the instructions to the letter for good results.
                              Dick Whittington
