I had a oil analysis done from my sour engine in my Chevelle. I got the results back and was looking to see if the were was any fuel in the oil. for the results it came back as a 5. it was done by ALS Laboratory Group.
oil analysis questions
Re: oil analysis questions
Dick I am not sure what you want but here it goes:
xFe 30
xCr 1
xPb 4
xCu 12
xSn 2
xA1 5
xNi <1
xAg <1
Xti <1
xV <1
xSi 6
xNa <1
xK <5
xMg 62
xCa 2942
xP 1091
xZn 1275
xMo 167
xB 12
xBa <1
xVIS100 8.8
xTBN 4.8
xMN <2
CoolANT no
Water <0.05
soot 0.3
Fuel 5- Top
I am guessing 5% which indicates to me that either the car is running rich or it is not being run enough at a time to get the choke open.
Search for oil sample and see the samples that I posted a month or so back.Dick Whittington- Top
the engine builder who assembled my engine and disassembled after the failure said the cause of the failure was fuel wash. so would this analysis back up his claim?- Top
Fuel wash will definitely screw up the world. Scored cylinder walls, bearings, etc. It is possible that you have a fuel pump diaphragm with a small pin hole in it.Dick Whittington- Top
Keith, if the pump was NOS or NORS, it is possible that it is not compatible with ethanol fuels, which have propensity for attacking rubber.Dick Whittington- Top
