oil analysis questions - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    I had a oil analysis done from my sour engine in my Chevelle. I got the results back and was looking to see if the were was any fuel in the oil. for the results it came back as a 5. it was done by ALS Laboratory Group.
    • 15706
    Re: oil analysis questions
    The best answer should be from the lab that did the tests.
    • Dick W.
      • 10483
      Post the results. Fuel dilution can be expressed in several ways
      Dick Whittington
      • Keith B.
        • March 7, 2008
        • 928
        Dick I am not sure what you want but here it goes:
        xFe 30
        xCr 1
        xPb 4
        xCu 12
        xSn 2
        xA1 5
        xNi <1
        xAg <1
        Xti <1
        xV <1
        xSi 6
        xNa <1
        xK <5
        xMg 62
        xCa 2942
        xP 1091
        xZn 1275
        xMo 167
        xB 12
        xBa <1
        xVIS100 8.8
        xTBN 4.8
        xMN <2
        CoolANT no
        Water <0.05
        soot 0.3
        Fuel 5
        • Dick W.
          • 10483
          xFe 30
          xCr 1
          xPb 4
          xCu 12
          xSn 2
          xA1 5
          xNi <1
          xAg <1
          Xti <1
          xV <1
          xSi 6
          xNa <1
          xK <5
          xMg 62
          xCa 2942
          xP 1091
          xZn 1275
          xMo 167
          xB 12
          xBa <1
          xVIS100 8.8
          xTBN 4.8
          xMN <2
          CoolANT no
          Water <0.05
          soot 0.3
          Fuel 5
          I am guessing 5% which indicates to me that either the car is running rich or it is not being run enough at a time to get the choke open.
          Search for oil sample and see the samples that I posted a month or so back.
          Dick Whittington
          • Keith B.
            • March 7, 2008
            • 928
            the engine builder who assembled my engine and disassembled after the failure said the cause of the failure was fuel wash. so would this analysis back up his claim?
            • Dick W.
              • 10483
              Fuel wash will definitely screw up the world. Scored cylinder walls, bearings, etc. It is possible that you have a fuel pump diaphragm with a small pin hole in it.
              Dick Whittington
              • Keith B.
                • March 7, 2008
                • 928
                I will say the fuel pump was band new two years ago. maybe I got a bad one. thanks for all your help.
                • Dick W.
                  • 10483
                  Keith, if the pump was NOS or NORS, it is possible that it is not compatible with ethanol fuels, which have propensity for attacking rubber.
                  Dick Whittington
                  • Keith B.
                    • March 7, 2008
                    • 928
                    It was a service replacent Delco from the dealer
