1967 Choke Coil Part Number - NCRS Discussion Boards
  • Gary B.
    • February 1, 2005
    • 33
    Can anyone give me the correct GM part number for a 1967 Choke Coil on a 327 300 HP?
  • Scott S.
    • September 11, 2009
    • 1961
    Re: 1967 Choke Coil Part Number
    Gary,
    The part number for the "Auto Choke Asm." in the AIM is 3893243 (UPC 6-C2, Item 10), but I didn't find that part number listed in my old P&A books.
    My '67 has the L79 engine, I don't know for sure whether the same Auto Choke Asm. was used on 300hp and 350hp engines (UPC L79-A1 & A2 do not mention a different Auto Choke Asm.). I checked the actual coil on mine, it is stamped "7149" on the flat part of the coil.
    • David L.
      • July 31, 1980
      • 3310
      Gary,
      My 1967 Chevrolet Parts Catalog (April 1967) lists the following (Automatic Choke Control Thermostat Asm.) in Gr. 3.750:
      66 PASS., CORVETTE w/Sp./H/Per. (327,427)
      67 CORVETTE w/H/Per. (427).........................................GM # 3887148
      65-66 PASS., CORVETTE (396, 427)(exc. Sp./H/Per.).......GM # 3869926
      Nothing for 66 or 67 Corvette w/base engine.
      HOWEVER, My 1967 Chevrolet Parts Catalog (July 1967)
      lists GM # 3887148 for "67 CORVETTE" (all models, I assume) instead of "67 CORVETTE w/H/Per. (427)".
      My Nov. 1981 Corvette Parts Catalog lists GM # 3887148 for "67 Y" (all 1967 Corvette models).
      Dave
      • William C.
        • July 15, 2009
        • 239
        Gary..3887148 is the correct part number per the Parts Book. This number is for all 67's..Bill
          • 43222
          Originally posted by Scott Smith (50839)
          Gary,
          Scott-----
          PRODUCTION and SERVICE part numbers for choke thermostats are different. That's because the PRODUCTION piece was supplied as a complete assembly with coil, cover, and rod. In SERVICE, the parts were only available separately.
          • Peter L.
            • May 31, 1983
            • 1930
            Gary - The Thermostat Assy is in G/N 3.750 and the REV 9-71 P&A shows p/n 3887148. Pete
              • 43222
              Pete and Gary-----
              GM #3887148 is GM-discontinued. However, reproductions are available in the Corvette marketplace from vendors like Dr. Rebuild.
              Caution: I believe the last manufacturer of these choke coil thermostats was Standard Motor Products, and I don't think they manufacture them anymore. I expect that all the Corvette vendors obtain their stock directly or indirectly from Standard Motor Products. So, just how much longer these things will be available is anyone's guess.
              • Ray K.
                • July 31, 1985
                • 372
                Gary
                The thermostat ( coil ) is indeed #3887148. If you need it, the cover that goes over the thermostat is #3864866. Also, the rod from the thermostat to the choke valve is #3881440
                Ray
                  • 43222
                  Originally posted by Ray Kimminau (8917)
                  Gary
                  Ray
                  Ray-----
                  You can still get the cover from GM, but that's it.
                  • Gary B.
                    • February 1, 2005
                    • 33
                    Thanks all for your assistance.
                    • Scott S.
                      • 1961
                      Does the 3887148 Coil have "7149" stamped into the spring-coil itself (as some parts have a final/finished part number one digit different from the component part numbers), or do I have the wrong choke coil for a '67 SB?
                      • David L.
                        • July 31, 1980
                        • 3310
                        Gary
                        Ray
                        There's a NOS 3881440 choke rod currently on Ebay courtesy of ........................
                        Dave
                        • Scott S.
                          • 1961
                          Dave
                          Dave,
                          That listing says "NOTE: Do NOT confuse the carb. choke rod with the auto. choke rod!"
                          I see that same rod on my Holley Carb, but I thought we were talking about the component parts of the Auto Choke Asm.?
                          What is the correct original GM part number for the '67 SB Auto Choke Rod?
                          • David L.
                            • July 31, 1980
                            • 3310
                            Gr. 3.752 in 1967 Chev. Parts Catalog (Apr. 1967)
                            3881888 ---- 66-67 CORVETTE w/Sp. H/Per.(327) described as "ROD, auto choke (w/3893244)", $1.11
                            3881888 replaced with 3917616 in July 1968 as per Chev. Parts History
                            3881866 ---- 66-67 CORVETTE (327)(exc. Sp. H/Per.)
                            described as "ROD, choke", $0.29 in Apr. 1967 catalog
                            described as "ROD, auto choke" in Oct. 1968 catalog
                            Dave
                            • Ray K.
                              • July 31, 1985
                              • 372
                              Gary, Scott, all
                              After I took a second look today, when my eyes were fresh, I believe that I made an error as to the part number 3881440 being the auto choke rod. That number is incorrect.
                              While the thermostat is the same for base 300HP and SPHP350, the choke rod is not. The correct number for the 300HP motor is #3881866. This number was available until 1972 /73 or a bit beyond: cannot determine history after that, most likely discontinued. The correct number for 350HP (L79) is #3881888 which was replaced by #3917616 in 7 /68. This number appears to have been good for several more years.
                              Ray
