1967 Choke Coil Part Number - NCRS Discussion Boards
    • 43222
    Re: 1967 Choke Coil Part Number
    Originally posted by Ray Kimminau (8917)
    Gary, Scott, all
    After I took a second look today, when my eyes were fresh, I believe that I made an error as to the part number 3881440 being the auto choke rod. That number is incorrect.
    While the thermostat is the same for base 300HP and SPHP350, the choke rod is not. The correct number for the 300HP motor is #3881866. This number was available until 1972 /73 or a bit beyond: cannot determine history after that, most likely discontinued. The correct number for 350HP (L79) is #3881888 which was replaced by #3917616 in 7 /68. This number appears to have been good for several more years.
    Ray
    Ray-----
    The GM #3881866 was discontinued without supercession in September, 1977. The GM #3917616 was discontinued without supercession in March, 1997.
    • David L.
      • July 31, 1980
      • 3310
      Scott,
      I do not know the correlation between the 4-digit number on the choke coil and the GM part number. I assume the 4-digit number is the vendor part number. I have a NOS choke assembly, GM # 3973497 (in service since March 1970) for my 1970 Camaro SS350 long term project and it is stamped "6650" on the coil part. The 1970 Camaro AIM part number number is 3973475 for the L48 option.
      I have an original choke coil from my 1966 Corvette 300 HP cast iron intake manifold but finding it may be difficult.
      Dave
      • David L.
        • July 31, 1980
        • 3310
        #18
        Originally posted by Scott Smith (50839)
        Does the 3887148 Coil have "7149" stamped into the spring-coil itself (as some parts have a final/finished part number one digit different from the component part numbers), or do I have the wrong choke coil for a '67 SB?
        Scott,
        Yes, it appears that your choke stamped "7149" on the coil is GM # 3887148. Refer to the link below.
        Dave
        https://www.forums.ncrs.org/showthre...tment&uid=2276
        • Scott S.
          • September 11, 2009
          • 1961
          #19
          Originally posted by David Liukkonen (3775)
          Scott,
          Dave
          Thanks Dave!
