1967 small block with C60
The first place I see the RH inner fender Hose Clip called out is on UPC C60-D3 (Item 8, GM 3841336). It is mounted (vertically) 3.50" back from the rear edge of the dust shield, and 5.25" down from the top of the inner fender.
This same Hose Clip is next called out on C60-D7, referencing existing dimples (for drilling) on the "forward set" (View E, RPO L36) and existing dimples for the "rearward set" (View A). The main drawing shows TWO Hose clips installed.
Does a 1967 small block with C60 use BOTH Hose Clips?
(Note: The same Hose Clip is called out a 3rd time, UPC L36-A4, only ONE Hose Clip shown in the main drawing for the big block)
) is shaped more like the Repro examples sold by the vendors. Neither hose clip has holes separated by 3.13” (measured center-to-center).
