Re: Rusty bores
Joe R,
Silly thought...
You seem very convinced in going the 454 route despite the expense.
You might be best off buying a used 454 motor, and adding your intake and carb to it to make it "look" original. Oil up the bores of your current motor, bag it and set it aside. I suspect it might be cheaper.
Patrick
Joe R,
Silly thought...
Patrick
You're right, that would be another option. But I will probably use the block I have. I'm mostly interested in performance while maintaining a stock appearance.
