Rusty bores - NCRS Discussion Boards
Rusty bores
    • 11692
    #31
    Re: Rusty bores
    Joe R,
    Silly thought...
    You seem very convinced in going the 454 route despite the expense.
    You might be best off buying a used 454 motor, and adding your intake and carb to it to make it "look" original. Oil up the bores of your current motor, bag it and set it aside. I suspect it might be cheaper.
    Patrick
    • Joe R.
      • May 31, 2006
      • 1822
      #32
      Re: Rusty bores
      Joe R,
      Silly thought...
      Patrick
      Patrick,
      I'm not really hard over on the 454 route. I'm just weighing my options and asking lots of questions. You're right, that would be another option. But I will probably use the block I have. I'm mostly interested in performance while maintaining a stock appearance.
      Joe
        • 11692
        #33
        Re: Rusty bores
        Originally posted by Joe Raine (45823)
        Patrick,
        Joe
        Here's a short block if you wanted:
        GM crate motor, GM crate engine, chevy crate engine, chevy crate motor, chevrolet crate engine, chevrolet crate motor, chevy high performance engines, GMPP, GM Performance Parts, crate motor, crate engine, High performance engines
        I think you'd get as much benefit from taking it apart and tanking it, then carefully cc'ing the heads, port matching it and doing a bit of head work. Far cheaper, that's for sure.
        Patrick
          • 43281
          #34
          Re: Rusty bores
          Patrick
          Patrick------
          ...however, this is a Gen VI block and will not be externally identical to a Mark IV. There may also be some compatibility issues using Mark IV heads. All-in-all, though, this is an excellent shortblock.
            • 11692
            #35
            Re: Rusty bores
            Patrick------
            If Mark IV head would fit, I suspect a little orange paint and no one will know the difference.
              • 43281
              #36
              Re: Rusty bores
              Patrick------
              That plastic timing cover and configuration of the front of the block would give it away.
              • Michael F.
                • 745
                #37
                Re: Rusty bores
                my 67 435 is fast, but my 03 zo6 will kick its butt with radio and air blasting away, but 67 way more fun
                Michael
                70 Mulsanne Blue LT-1
                03 Electron Blue Z06
                • Joe R.
                  • May 31, 2006
                  • 1822
                  #38
                  Re: Rusty bores
                  All,
                  I think I have returned to sanity. Well, maybe that's a bit of a stretch. Anyhow, I think I will stick with my 427 crank. I probably don't want to risk removing any metal from the block. Along the same vein, I was thinking about having a machine shop put larger exhaust valves in my 3873858 heads. But I don't think I really want to chance it. Thanks for all the advice!
                  Also, here's a link to another thread I started that is about engine storage. Maybe I should have just tacked this one onto it. Here it is:
                  https://www.forums.ncrs.org/showthre...114#post549168
                  Joe
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    #39
                    Re: Rusty bores
                    All,
                    Joe
                    here is what i used for engine storage. http://webcache.googleusercontent.co...www.google.com
                      • 43281
                      #40
                      Re: Rusty bores
                      All,
                      Joe
                      Joe======
                      I would not recommend having the valves enlarged in any head casting and installing valves which are larger than GM ever installed in that casting. Besides, for your engine, you would not gain enough, if anything, from such a change to even make it worthwhile.
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        #41
                        Re: Rusty bores
                        Clem,
                        So that's the good stuff, eh? I assume you put it in the bores. Did you use it anywhere else?
                        Joe
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          #42
                          Re: Rusty bores
                          Clem,
                          Joe
                          i also used it on assembled engines by squirting it into the exhaust ports before plugging them.
