C3 Clocks help - NCRS Discussion Boards
C3 Clocks help
  • Kenneth T.
    • March 23, 2008
    • 631
    C3 Clocks help
    My clock quit, as most do and I replaced it with a Quartz movement clock.
    Now, I miss the stutter of the second hand and the snap of the solenoid winding it up. I have several clocks that stop and go, no coil issues, they will snap when the contacts are made. It seems that they stop just prior to closing the contacts.
    If I apply slight pressure to the spring mechanism they will continue. Has anyone tried to increase tension on the mechanism buy clipping the spring?
    I have lubed them and watched them go for hours, sometimes minutes, but they are not reliable for judging.
    Ken
  • Edward J.
    • September 15, 2008
    • 6941
    Re: C3 Clocks help
    Ken, when I took my clock out of the 72 ,I took it apart and blew the dust out and 3n1 oiled it and cleaned the points its been 2 years now. maybe I just got lucky.
    • Kevin G.
      • February 1, 2005
      • 1076
      Re: C3 Clocks help
      Ken,
      If you page through your owners manual, you will find that an annual cleaning and lubrication is recommended. I wonder how many owners actually went to the trouble of tearing the center stack out to perform this maintenance?
      Best of luck,
      Kevin
      • Kenneth T.
        • March 23, 2008
        • 631
        Re: C3 Clocks help
        Kevin,
        Annual? I have all the Corvette News mags that offered tips on suff to do, but my car is forty years old and I do not want to put the real clock back in until I can hope it works long enough to pass without me having to stumble into the car and bump it to get the clock started. Question? Will the judges notice if I do?
        Ken
        • Kevin G.
          • February 1, 2005
          • 1076
          Re: C3 Clocks help
          Just have someone distract the op's judge just long enough to snap the knob and get it started!
          • Gerard Q.
            • February 1, 2000
            • 284
            Re: C3 Clocks help
            I replaced the quartz clock in my 71 with one that had a NOS movement. I purchased it from the Clock Works and it's been working for the past 3 years without a problem. They can also restore your clock.
            The Clock Works is your full-time automotive clock service center! With over 20,000 units serviced, we are the first choice for automobile clock sales and service. No radios, no gauges, no speedometers, no tachometers... Just clocks done right!
            • Bob D.
              NCRS Shipping Data Report Manager
              • April 30, 1996
              • 788
              Re: C3 Clocks help
              I had D&M redo my clock as original and it works great. Keeps time perfectly. They use brass gears in place of the plastic used by the GM contractor.
              • Kenneth T.
                • March 23, 2008
                • 631
                Re: C3 Clocks help
                My thanks to Gerard and Bob, Kevin of course; always a good source,for your input. The prices for Clock Works are very reasonable.
                I have a Q clock in the car now and wanted my original back. So, I did clip the spring, call it a britz if you will. It has been running on the bench for a whole day now and I think increasing the tension has helped.
                If it continues until tomorrow I will consider pulling the dash and putting it back when the weather improves.
                Again, thanks all...this is spring fever at work, I can't help but tinker with all this stuff.
                Ken
