68 : Master Cylinder Cap - NCRS Discussion Boards
  • Jeff P.
    • 797
    Hello everyone,
    I was told at the recent Chapter meet that I had the wrong cover. I located one , The front cup says "Service with"up top and "Delco parts" on the bottom. The rear cup says "Use Delco" up top and "Brake Fluid" on the bottom.The manual says the rear cup has" Use Delco Brake Fluid ONLY".The gentleman says the one I purchased is correct. Any photos or help would be much appreciated. Thanks, Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 68 : Master Cylinder Cap
    USE DELCO BRAKE FULID on one and SERVICE WITH DELCO PARTS on the other
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Jack C.
      • 1090
      Here is an original one. Not the best pix. Grant Wong has this down cold. You can reach out to him.
      Jack Corso
      • Jack C.
        • 1090
        Jeff, I don't think the USE DELCO BRAKE FULID ONLY is correct for the 68's, but you never know.
        Originally posted by Jeff Pollard (15573)
        Hello everyone,
        Jack Corso
        • Gene M.
          • March 31, 1985
          • 4232
          The 68 master cylinder cap should have the "J1703". Other than that it looks the same as a 67.
          • Keith B.
            • March 7, 2008
            • 928
            if that is the case then the letters should not be stacked.
            • John C.
              • December 31, 2004
              • 616
              Jeff
              The JG is wrong. The 67 and 68 caps are the same. Attached is a photo of a 68 cap.
              The SAE J1703 text did not come along until 1969 or possibly late 68.
              John
              • Jeff P.
                • 797
                Thanks all, those are great pics Jack and John. This is the cover I have. Both pics show the covers to be mainly silver cad. The one I have looks more of the yellow cad. Could this just be the picture . Thank You again, Jeff This is good news !
                • John C.
                  • December 31, 2004
                  • 616
                  The finish should have a yellow tint. In my picture you are seeing the bare steel. I was trying to remove some rust from the cap with "America's Safest Rust Remover" and it removed the finish. Good product, just don't use on mc caps.
                  John
                  • Jeff P.
                    • 797
                    More good news,thank you John.
                    • Jeffrey S.
                      • May 31, 1988
                      • 1879
                      The original cap on my early '69 is also the same.
                      Jeff
                      • Terry B.
                        • August 31, 1999
                        • 607
                        This thread needs some clarification. The judging manual seems to have added a word that does not appear on the '68 master cylinder cap. One dome has "Service with Delco Parts" and the other dome "Use Delco Brake Fluid" The word 'only' does not appear on the cap. That is where the JM is incorrect.
                        Has anyone found other mistakes in this area? The '68/'69 manual is going through revision at this time.
                        Terry Buchanan
                        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                        Corvettes Owned:
                        1977 Coupe
                        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                        2003 Electron Blue Coupe
                        2019 Torch Red Grand Sport Coupe
                        • Jeff P.
                          • 797
                          Opened the hood this morning to change covers. I had the correct cover all along. Thats ok, I'll make copies of this post and bring it along to future meets. Good part is we are always learning about these cars. Judges are human also. Jeff
                          • Paul B.
                            • April 30, 1995
                            • 482
                            I had the correct cover all along. Jeff
                            Jeff, as you know that car went through two NCRS Regionals, '03 Stone Mtn. & Pittsburgh, one Chapter meets, '04 Windsor NCRS Nat'l Convention for 4 Star Bowtie & two judging schools and it was never called on as being incorrect.
                            • Jeff P.
                              • 797
                              Nice to hear from you Paul. I sent you a PM. Jeff
