68 : Master Cylinder Cap - NCRS Discussion Boards
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 68 : Master Cylinder Cap
    My original owner 1968 has what should be the original master cylinder cap since I have not changed the cap or master cylinder. This is a FEB built car.
    The master cylinder cap is almost like what John Carlson's picture shows. The difference is where the word "BRAKE" is on John's picture.
    On my 68's cap "BRAKE" is located directly on top of the word "FLUID" like in
    BRAKE
    FLUID
    In place of the word "BRAKE" my 68's cap has SAE J1703. SAE is on top of the J1703.
    Is this the correct cap for a FEB built 1968?
    I rebuilt this master cylinder myself over 22-24 years ago with a rebuild kit and switched to silicone brake fluid.
    • John C.
      • January 1, 2005
      • 616
      Just for reference is a picture of the style Jim refers to.
      I've always thought this style started in 69, but maybe there was mixed usage for a while.
      John
      • Grant W.
        • December 1, 1987
        • 407
        #18
        Hi John and Jim
        Jim the cap you have is incorrect for a 68- SAE is on top of the J1703 started in 1969.
        John the picture you provided above is for 69 to 72
        1967 master cylinder cap is a carry over to 1968 only. I'm pretty sure of this.
        Hope this helps.
        Grant
        • Floyd B.
          • November 1, 2002
          • 1050
          #19
          I resurrected this thread because I know the chrome after market cap I have for my early production '69 needs to be replaced. I've read this thread and pg 73 of the TIM&JG a couple times but I'm still not sure which version of cap would be typical for an Oct 2, 1968 build.
          Would someone please provide a list or table showing the various cap versions and the approximate date or VIN of each change? Sounds like a good article for the Restorer - perhaps one already exists?
          Thanx
          "Drive it like you stole it"
            • 43246
            #20
            One thing to keep in mind folks: this cap was not just used on Corvettes. It was used for many other applications, too. It's very possible that there was more than 1 stamping die for this part and features like the inscriptions varied slightly from die-to-die.
            • Floyd B.
              • November 1, 2002
              • 1050
              #21
              D'oh! You went and made it even more confusing.
              • Edward B.
                • March 29, 2013
                • 691
                #22
                Floyd, we did a little research on this for the first generation Camaro and here are the results:
                Version 1 "Use Delco Brake Fluid" (Bottom left photo)
                All 1967 & 1968 cars & the following 1969 cars:
                11D 1968
                12B 1968
                01C 1969
                03B 1969
                Version 2 "Use Delco SAE J1703 Brake Fluid" (Bottom right photo)
                The following 1969 cars:
                01C 1969
                03E 1969
                07A 1969
                09C 1969
                09D 1969
                It's not totally conclusive, but it's a start. It also appears there was a transition in mid 1969 when both were used.
                Hope this helps
                Ed
                • Floyd B.
                  • November 1, 2002
                  • 1050
                  #23
                  Ed,
                  If I'm interpreting this correctly, it appears from this sampling that the changeover period for the Camaro was Jan - Mar 1969. Am I interpreting the date codes correctly?
                  Thanx
                  • Edward B.
                    • March 29, 2013
                    • 691
                    #24
                    You are correct Floyd.
                    Ed
