Need help to de-code 63 vin & trim I have. - NCRS Discussion Boards
    Re: Need help to de-code 63 vin & trim I have.
    Originally posted by Domenic Tallarita (51287)
    By the way , I noticed that the trim tag didn't have rivits. It looked as if it were spot welded. IS that normal?
    DOM
    Dom -
    I think you'll find that the trim tag is attached with two 3/16" pop-rivets, and the VIN plate is spot-welded.
    • Domenic T.
      • January 29, 2010
      • 2452
      John,
      Thanks for straightining me out, I had it backwards as I was upside down and not as young as I was. Also gun shy because when I looked for my tags on my 67 they were both gone. Removed because of AS/IS sale.
      All I could think of was that maybe my 67 tags were stolen instead of removed as they said and they also tried to steal the 63 tags with a dull drill bit. The vin actually looked like someone tried to drill it out with a dull bit and gave up. I felt the back of the tag and it had a dimple ( like the back of a pop rivet) and never saw a spot weld leave one like that before.
      DOM
      • Timothy B.
        • April 30, 1983
        • 5186
        #18
        Dom,
        Sounds like the vin tag is like all other 63's. I think everything is in order except the parts that were missing.
        Definately give the Jeep search a try, I bet it's somewhere out there. Can you tell me what bolt the round tag is mounted to on the rear cover. This indicates 3.36 posi, I believe it should be on the passenger side bolt just above horizontal like the 2 o"clock position on the rear cover.
        • Domenic T.
          • January 29, 2010
          • 2452
          #19
          Tim,
          I think you are right but I will go double check later today.
          DOM
