big tank repair - NCRS Discussion Boards
big tank repair
  • Mike M.
    • May 31, 1974
    • 8384
    #46
    Re: big tank repair
    Originally posted by Ron Reeves (22763)
    Mike, I'm sorry but I'm not sure what holes your referring to, could you please give me a little more information.
    get up under any 63-7 non-tanker and look for the rivets that hold the metal reinforcement plate. a tanker will have no evidence of the rivet holes ever being drilled like all small tank mid-years.mike
    • Ron R.
      • May 31, 1993
      • 190
      #47
      Re: big tank repair
      Mike, I will send pictures of the bulkhead showing the plates, please let me know what you think....thanks agree for the valuable information...
        Re: big tank repair
        Ron -
        Photo below shows the vertical reinforcement that was riveted to the back side of non-tanker rear bulkheads; tankers didn't use it.
        • Wayne M.
          • March 1, 1980
          • 6414
          #49
          Re: big tank repair
          Ron -
          Here's a pic I took at Bloomington '87, showing NO metal reinforcement (where the crayon "51" is). IIRC, this was on a split window; don't know the VIN, and can't explain the dark fiberglass.
          I still think that early '63's (for which Ron's # 3022 applies) would not have had this feature; anybody got a '63 AIM with revision note ?
            Re: big tank repair
            Wayne -
            You may have nailed it - I don't show that 3850114 reinforcement in my AIM's until 1964; looks like it was '64-'67 only.
            • Loren L.
              • April 30, 1976
              • 4104
              #51
              Re: big tank repair
              Nice informational thread, but before you do anything, drain the tank and let it sit open for 7-10 days, drop a light into it and let your digital cellphone TV camera go down and take pictures. Maybe it's simple as a piece of metal that rubbed against the tank from outside until the hole appears.
              • Ron R.
                • May 31, 1993
                • 190
                #52
                Re: big tank repair
                Excellent advice, will supply plenty of pictures so as learn how to.....thanks again,
                  • 43221
                  #53
                  Re: big tank repair
                  Wayne -
                  Johm-----
                  ... and that GM #3850114 doesn't look like a part number that would have been around for most, if not all, of the 1963 model year.
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    #54
                    Re: big tank repair
                    Originally posted by Mike McCagh (14)
                    here's another sign of real 36 gall tankers: no evidence of the holes for the rivets that fasten the metal reinforcement plate to the back side of the partition between the cockpit and the area where a non-36 gal tank resides. mike
                    This is a little late, but I finally located this pic, which shows where the six rivet holes would be if the metal reinforcement was removed for the N03 filler nozzle on a coupe.
                    This is of my late-late '65 convertible, but the rear partition "tub" is the same for both body styles. The real sloppy job # 204 is visible. Took this shot when I had my regular 20 gal tank out.
                    • Ron R.
                      • May 31, 1993
                      • 190
                      #55
                      Re: big tank repair
                      Any response is never too late, first their is no evidence off any holes for the metal reinforcement on the bulkhead, their is two holes for the jack below the driver's seat but only holes, no evidence that a rivet was ever attached. The bracket to hole the jack is on the passanger side in the rear. I really need to send pictures to you.
                      Again, my car is a early Nov. car which I purchased in 1968, radio delete with racing seat belts and rear scoops at one time. Cat appeared to be a bright blue color at one time, now dark blue as purchased. So the car was repainted between 1963 to 1968.
                      • Ron R.
                        • May 31, 1993
                        • 190
                        #56
                        Re: big tank repair
                        Wayne please take a few moments and look over......
                        • Ron R.
                          • May 31, 1993
                          • 190
                          #57
                          Re: big tank repair
                          Originally posted by Bob Jorjorian (1619)
                          If your car was built the first week of November, with a 36 gallon tank, it HAS to be a Z06. Bob
                          please see additional picures in my original thread
                          • Ron R.
                            • May 31, 1993
                            • 190
                            #58
                            Re: big tank repair
                            please look over additional pictures
                            • Wayne M.
                              • March 1, 1980
                              • 6414
                              #59
                              Re: big tank repair
                              Nice shots, Ron. For a '63 tanker in the early 3000's VIN range, you could consider it to be considered (still) a "pilot" 36gal car, IMO. Probably no more than a dozen had been built prior to yours. I see you've lifted the cover up to expose the tank and fill/vent hoses. Anything written on the tank ?
                              • Ron R.
                                • May 31, 1993
                                • 190
                                #60
                                Re: big tank repair
                                No that I can remember, I cleaned up the tank and sprayed w gray primer.
