i already searched the archives to save embarrassment, but couldn't find any info...went to change oil & filter (canister type) and stupididly forgot the reassembly sequence of ALL the parts. plus, i wanted to make sure the previous owner did it right. i have 1- large bolt, 1-canister, 1-filter, 1-spring, 1-cone shaped thing, 1-star type washer, 1- small rubber washer and 1- small metal washer. i know the obvious...filter into the canister. DUH! where do ALL the other parts go, correctly. i'm thinking run the bolt through the canister first. then the spring. then the cone shaped thing. then the filter. where do the washers go?
any input will be greatly appreciated. thanks in advance.
