valves seals 1966 L72 - NCRS Discussion Boards
  • Carl B.
    • March 1, 2007
    • 89
    what type valve seals were used 1966 L72 (umbrella or o-ring ) thanks #6 plug fouled oil ,compression 200 psi all cylinders any special tools needed for seal removal have valve spring removal tool also any special brand of seal probably comes in head gasket set
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: valves seals 1966 L72
    Carl -- going by the service catalogs, they were using the black rubber umbrella seals for all production big blocks (396, 427), still, as of Oct '66.
    The pic is shown in post #7 of this thread; link:
    https://www.forums.ncrs.org/showthre...77878&uid=6433
      • 15706
      Do some archive diving. If you have the original single spring/damper setup, which are prone to breaking, you should replace all with the later integral dual spring/seal/retainer.
      This has been thoroughly discussed including a thread earlier this week.
      • Carl B.
        • March 1, 2007
        • 89
        Thanks read info few days ago but not find. got it now I will remove the valve springs and check seal type
        • Carl B.
          • March 1, 2007
          • 89
          still need info on 1966 L72 motor read tech discussion on valve seals removed intake spring from #6 double valve spring with damper white umbrella seal with expander spring what manufactuer and a tool to remove and install seal any help would be greatly appreciated.
          • Joe R.
            • May 31, 2006
            • 1822
            Carl,
            Do your springs look like the pictures I attached? The seal I got from GM is more like yellow. As far as I know there is no separate tool for the valve seals. You replace the whole spring assembly, including the keepers of course, with the valve spring compressor you already have.
            I can provide more info on the parts I got from the Chevy dealer if that proves necessary.
            Joe
            • Larry T.
              • May 15, 2007
              • 404
              Joe
              Joe,
              How long ago did you order these? My local dealer told me today they have been discontinued and that the kit of 16 under #12371061 does not include retainers or seals.
              Larry
              • Carl B.
                • March 1, 2007
                • 89
                valve seal on valve guide retainer looks like seal could be attached to it talked to person built motor was told perfect circle makes seal no specific info on their site am I missing something ? thanks for your help
                • Carl B.
                  • March 1, 2007
                  • 89
                  Originally posted by Larry Tape (47364)
                  Joe,
                  Larry
                  I did'nt order any seals I'm trying to find replacement seals so far no luck thanks for your help
                    • 43285
                    Carl------
                    If the valve seals on the engine are WHITE teflon with a spring metal band securing it to the valve guide and a circumferential spring wire applying pressure to the valve stem, that is an aftermarket seal. It was not used in PRODUCTION.
                    • Clem Z.
                      • January 1, 2006
                      • 9427
                      here are the 3 types of positive seals left to right. rubber outer with a teflon insert,all teflon and the metal outside with a rubber seal
                      • Carl B.
                        • March 1, 2007
                        • 89
                        looks like middle all teflon seal thanks for your help Carl
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          Joe,
                          Larry
                          Larry,
                          I dug up my receipt from Weber Chevrolet. It is dated February 23, 2009. That's a real bummer! Maybe if you poke around on the internet or try a few Chevy dealers you might get lucky and find the old configuration. By the way, the 12371061 set of 16 3970627 valve springs listed for $302.86, I got them discounted to $258.72, just because I am such a nice guy!
                          Joe
                          • Joe R.
                            • May 31, 2006
                            • 1822
                            Carl,
                            Check out this thread for some recommendations from the heavy hitters on the keepers and shims:
                            https://www.forums.ncrs.org/showthre...75916&uid=8375
                            Joe
                            • Wayne M.
                              • March 1, 1980
                              • 6414
                              Clem -- is it possible to tell, from looking at or measuring the machined guide, what type of seal was / should be installed ? These guides were machined by a previous owner. (see pic) dia 0.53", height (bevelled tip down to circumferential step 0.35".
