valves seals 1966 L72 - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: valves seals 1966 L72
    Originally posted by Wayne Midkiff (3437)
    Clem -- is it possible to tell, from looking at or measuring the machined guide, what type of seal was / should be installed ? These guides were machined by a previous owner. (see pic) dia 0.53", height (bevelled tip down to circumferential step 0.35".
    most all engine builders use the all teflon seal and come in diferent diameters for what the guide was cut to. .530 is a standard size along with .500.
    • Carl B.
      • March 1, 2007
      • 89
      Think Ifound type of seals for my motor crane (out of business) and comp cams positive stop teflon will remove seal and check for machined guide checked overhaul manual and got a clear picture of origanal springs and seals checked crane cam in car against spec's in overhaul manual same lift,valve spring height and rocker ratio Thanks again for all your help
