1963-1994 Unique-To-Corvette Part - NCRS Discussion Boards
    • 43219
    #31
    Re: 1963-1994 Unique-To-Corvette Part
    Originally posted by Thomas Hoyer (44463)
    Hmmmm,
    Maybe 69% were manual transmissions?
    Reverse light switch?
    Thomas-----
    Offhand, I don't know what the percentage was that were manual transmission. However, there were several manual transmissions that were used over the 63-94 period and only the C4 manual transmissions were Corvette only.
    Several different back-up switches were used over the 63-94 period.
      • 43219
      #32
      Ok Joe.....We're gonna keep you up all night! Good thing you're on the west coast.
      Ok I'll take another shot at it. Not sure if the same one was used on pass cars too, but........
      cigarette lighter housing?
      Richard------
      Several different cigarette lighter housings were used over the 63-94 period. Most are functionally interchangeable but none are unique-to-Corvette. In fact, they were used pretty much across all GM car and truck lines.
        • 43219
        #33
        Originally posted by Rich Pasqualone (49858)
        Inside rear view mirror pivot screw.
        Rich------
        The same screw was used for 1963-76 but not later. Plus, it was not a Corvette-unique piece.
          • 43219
          #34
          Yep, I didnt catch that. Then I would guess the side yoke bearings common to IRS rears.
          Wayne------
          The 63-79 side yoke bearings were the same, but not later.
          • Gerard F.
            • June 30, 2004
            • 3805
            #35
            As sort of a "lead-in" to another post I'm going to put together when I get around to it, there was one unique-to-Corvette part that was used on the vast majority of Corvettes built between 1963 and 1994. I believe this was the ONLY unique-to-Corvette part that was used over such a long period. Now, I want to emphasize again this is a unique-to-Corvette part and not a part used for non-Corvette applications or a standard item like fasteners and things like valve stem cores.
            Does anyone know what it is?
            Lower rear oil drain plug?
            Read your previous post
            Otherwise does it have something to do with the fiberglass body, a ground strap?
            Jerry Fuccillo
              • 43219
              #36
              Jerry------
              There were 4 different oil drain plug part numbers used over the 1963-1994 period and only 1 of them was Corvette-unique. That was the GM #10110927 used for 90-95 LT5 (ZR1).
              The part in question is not related to the fiberglass body or any ground strap.
              • Thomas H.
                • August 31, 2005
                • 1058
                #37
                So.... I'm still focusing on the 69% or the Corvettes producted had this part clue. This tells me it was part of an option.............
                If it is not that little thingy that connects to the friggment and improves the operation of the jankelbon used only in Corvettes, then I have no clue what it is!
                Tom
                2007 Z06, Lemans Blue
                  • 43219
                  #38
                  Tom
                  Tom------
                  It was part of certain options but it was also part of standard equipment.
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    #39
                    The 5 Qt Oil Pan..... (sometimes known as the base engine pan)
                      • 43219
                      #40
                      Tracy-----
                      If you're talking about the C2-C3 5 quart pan GM #3820000, that pan was only used from 1963 to 1974.
                      • Michael G.
                        • March 2, 2008
                        • 485
                        #41
                        How about the rear differential housing or the cover gasket.
                          • 43219
                          #42
                          Michael-----
                          There were at least 2 different housings used over the 63-79 period. All 63-79 used the same cover gasket, though, and the housings and gaskets were Corvette-unique. However, 1979 was the last year that used either housing or gasket. 1980-82 used a completely different housing and gasket. 1984-94 used 2 different housings and gaskets, depending upon whether manual or automatic transmission.
                          • Gerard F.
                            • June 30, 2004
                            • 3805
                            #43
                            Joe,
                            The Oil Pump Pickup Screen?
                            Do they serve any lobsters in North Carolina
                            Jerry Fuccillo
                              The "short" throwout bearing.
                                • 43219
                                #45
                                John------
                                There were actually several different "short" release bearings over the 1963-81 period. Some were 1-9/32", some 1-1/4", and some 1-7/16". They all became the 1-1/4" after the mid-70's, though. Early C4 also used a 1-1/4" bearing but it was different than that used earlier. Later C4 used another different bearing.
                                In any event, none of the C2-C3 bearings were unique-to-Corvette. At the moment, I'm not sure about the C4 bearings.
