1963-1994 Unique-To-Corvette Part - NCRS Discussion Boards
    • 43219
    #46
    Re: 1963-1994 Unique-To-Corvette Part
    Originally posted by Gerard Fuccillo (42179)
    Joe,
    The Oil Pump Pickup Screen?
    Do they serve any lobsters in North Carolina
    Jerry------
    You got it! The GM #3830080 oil tube and pick-up assembly is the part in question. This part, which is unique to Corvette applications, was used for all 1963-1994 Corvettes EXCEPT:
    1965-74 big block
    1975-79 ALL
    1990-95 LT5 (ZR1)
    Late 1994 LT1
    The "putting 2 and 2 together" I was talking about earlier is this: we should all know that the one common component for all 1963-96 model year Corvettes is the small block engine. So, it would seem likely that's where the part common to all would "reside".
    The next question is, what component that could be common to all 63-96 small blocks would be a Corvette-unique component? After all, small blocks are pretty ubiquitous across all Chevrolet car lines for a lot of years and most parts used on Corvette small blocks are common to those used for other cars. Those that are different and unique to Corvettes certainly didn't span 31 model years. Well, all except ONE didn't.
    That's where the post I made a few weeks ago comes in. I said that all Corvette small blocks used unique-to-Corvette oil pans, except 75-79. Now, all the Corvette-unique pans were not the same, so we know the pan is not the component in question here. However, I also said that the basic configuration of the 63-74 "5 quart" small block pan is the same as the basic configuration of the various 1980-96 pans. So, maybe something related to the pans would be the part in question here. And, that's exactly what it is.
    The same GM #3830080 first used for 1963 small blocks was used for E1994 small blocks and most Corvette small blocks in between those years. As far as I know, it is the ONLY Corvette-unique component used over the 1963-94 period.
    Now, you might ask why do we only go as far as E1994 with it? The basic original small block was used through 1996 in Corvettes, wasn't it, and L1994-96 used the same, basic configuration oil pan as earlier, didn't they? Yes, they did, but they didn't use the same oil pick-up. But, that's a story for another time.
    • Gerard F.
      • June 30, 2004
      • 3805
      #47
      Joe,
      I put two and two together just like you said, and followed your hints.
      Take after my Dad, a NYPD detective, the original Columbo (in my mind).
      So, are we going to do some lobster in North Carolina this July. I'm on the Road Tour as a navigator for Joe Ciaravino. Maybe we'll pick up some Canoli's going through Virginia.
      Jerry Fuccillo
      • Roy V.
        • April 8, 2008
        • 301
        #48
        Thanks Joe, very interesting thread you started, had us all putting on our thinking caps for awhile. Congrats to you too, Gerard for getting it right.
        Regards
        Roy
        1972 LT-1 Elkhart Green Coupe
        • Kenneth S.
          • July 31, 1981
          • 302
          #49
          Body mount shim 366981
            • 43219
            #50
            Ken------
            The GM #366981 was not used after 1982, so it never made it into the C4 era. Also, it was not unique to Corvettes. It was also used for some earlier passenger cars.
              • 43219
              #51
              Joe,
              Jerry------
              I'm afraid I won't be at the convention in July. As a matter of fact, though, I KNOW I'll be having lobsters (and steamed clams) in July since I'll be in New England for 2 weeks.
              I don't recall ever looking for lobsters in N. Carolina. I expect they have them there on about the same basis as you can find them out here. Not, at all, the same as New England. I once looked for a whole day for New England steamer clams in the Washington, D.C. and Maryland area and never found a single one.
                • 43219
                #52
                All------
                By the way, even though the GM #3830080 oil screen and tube was used on about 700,000 Corvettes over a period of about 31 years, you can't buy it from GM anymore. It's discontinued. However, all is not lost as it is available in the aftermarket from Melling under their number 55-S3 and Federal-Mogul/Sealed Power under their number 224-14227. Melling manufactures both of these and manufactured the GM piece for at least the last 20 years, or so.
                • John D.
                  • December 1, 1979
                  • 5507
                  #53
                  51 posts here I see for old Joe's nice question. Was the answer given as too lazy to read all the posts??? JD
                  • Tom P.
                    • February 1, 1982
                    • 69
                    #54
                    Joe:
                    Thanks for one of the neatest tutorials on Corvette history that I have seen in a long time!!!
                    Keep up the good work!!!
                    • Patrick T.
                      • September 30, 1999
                      • 1286
                      #55
                      Joe, I put two and two together just like you said, and followed your hints. Take after my Dad, a NYPD detective, the original Columbo (in my mind).
                      Jerry, I believe that Vinnie Peters once told me he was a retired NYPD Detective, maybe they knew each other. PT
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11323
                        #56
                        No cheating here John, you gotta' read 'em all like we did.
                        Just kidding, April Fools. It was Joe's reply March 29th, 2010, 09:46 PM. It's GM #3830080 oil tube and pick-up assembly.
                        Click Here.
                        Rich
                        • John D.
                          • December 1, 1979
                          • 5507
                          #57
                          Richard, Thanks for saving me an hour or more. Sorry I cheated. Yeah rite.
                          Joe, Thanks for the education. Much appreciated by all I am sure. Keep up the good work. JD
